Oil pan gasket change
Discussion in 'Technical' started by Tumbler, Jun 18, 2019.
  1. Tumbler
    Tumbler Member
    California
    73 Ford Maverick
    I'm changing out my old somewhat leaky cork oil pan gasket for one of those blue rubber Fel Pro gaskets. I just got the oil pan off, and I found that one of the sides of the timing cover isn't flush with the block. I had to take timing cover off a while back, and getting it back on was a huge pain. I remember had to squish down the cork gasket by tightening the oil pan bolts down a good amount before I had any hope of getting it aligned with the other bolt holes. It looks like I didn't get one side tightened down enough, and there's about a 1mm gap that was filled in with RTV.
    I'm wondering if I putting some RTV in this area would be a good idea? From reading around, I gather that RTV is not necessary with this gasket, except in the bearing cap corners.
  2. baddad457
    What engine is this ? The most important thing with the timing cover alignment is centering the front seal on the crankshaft. I would start over and remove the timing cover and get that centered on the crank before installing the oil pan and gasket.
    Rasit, 71gold and jasonwthompson like this.
  3. Tumbler
    Tumbler Member
    California
    73 Ford Maverick
    It's a 302. I forgot to mention that.
    I went ahead and filled the gap with permatex gasket maker, just because I needed to get the car back on the road. I was redoing the steering system, and it made sense to get to the oil pan as well. It seems to be holding, but I have a small leak coming from the back. Does anyone know what I should torque these bolts down to with a rubber gasket? Reading around, I've found numbers from 8-15 foot pounds. I went with 10 foot pounds.
    The crank seal was pretty tight when I put it on. Moving it around a bit didn't seem to create any gaps. It's been on there roughly a year and a half without leaking. I should fix this eventually, but taking this stuff apart again is not a job I'm looking forward to. So many things have to come apart.
