Oil pressure question with YouTube vid
Discussion in 'Other Automotive Tech & Talk' started by ptpdub, Aug 1, 2012.
  1. ptpdub
    ptpdub Member
    canada Sk.
    Vid explainers it fairly well. Is this normal or do I need a new oil pump. Perhaps is there another explanation?
    Thanks in advance
    Truck is a 1997 cherokee 4L 6 cylinder.
  2. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    I think you are fine, most cars run pretty low psi at hot idle, some new cars have a spec of min 4psi at idle. Based on the fact that your needle is halfway between 0 and 3 and that your oil pressure rises with rpm I would say there is nothing wrong there. I would find out what is the unit of measurement for your oil pressure in your owners manual though, my guess being that your car is metric that it is Bar measurement, which equals to 1 bar= 14.5038psi, so halfway between 0 and 3 would be 21.75ish psi which is perfectly good.
  3. ptpdub
    ptpdub Member
    canada Sk.
    hey, sounds like you know what you are talking about. thanks so much. the jeep was $450.00 so if it needs too many $ .............. well ............aint gonna happen. I am glad to hear it is good to go.
  4. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    More than likely its the sending unit, a very common problem on a 4.0. I would hook a gauge to it to make sure though.
