ok manual tranny guys need your help
Discussion in 'Technical' started by Will, May 19, 2003.
  1. Will
    Will I
    Waco
    74 2door - Small bumpers, 5.0 EFI, Tremec 3550, disc brake 8.8,MII front end, boosted
    I'm installing a T5 in my mav, using the manual mav pedals and mustang clutch pedal. everything is looking ok excpet for one thing, on the mav pedals there is not a stop, for the clutch pedal. for pushing the clutch or letting it out. could this cause any problems? is over travel a problem?
  2. bmcdaniel
    bmcdaniel Senile Member
    My clutch pedal goes to the floor, always did. No problem with over-travel. Not sure anymore about a stop at the top of it's travel. I'll look tomorrow. If the linkage is adjusted right I don't think you'll have a problem. I do remember I took out the large return spring up under the dash years ago. Made pushing the pedal easier.
  3. Will
    Will I
    Waco
    are you running cable clutch or hydraulic?
  4. bmcdaniel
    Neither. Mechanical linkage from a '66 Mustang.
  5. Mavaholic
    Every manual I've ever owned has always gone to the floor. I've never had a problem.
  6. Will
    Will I
    Waco
    alright, sounds like it wont be a problem then
