hi everybody,does anyone know of any companies that reproduce the bottom rear of the front fenders for mavericks? (in between the rear part of the wheel opening,and the front section of the door)mine are still there but getting soft. i am trying to keep from having to fabricate these sections. used fenders or pcs.cut off of damaged fenders would also be an option,if anyone has any,need right and left pcs.car is 70 maverick 2 dr.thanks everyone chuck.
check a junk yard.if you cant find any there, I might be able to hook you up with a r/f late nov./ mid dec., as im most likely getting a new right front fender..the area you described is still in top notch condition, just near the headlight is smashed pretty bad..and im too lazy/too cheap to get it fixed...so, if by then, your still minus one, ill let you know/you let me know..
