Pathfinder stereo
Discussion in 'Other Automotive Tech & Talk' started by lika, Jun 11, 2011.
  1. lika
    lika Señor Comet
    IA
    comet 71
    Went to the stereo store to replace my factory stereo in my 1999 Nissan Pathfinder. They said it would cost like a million dollars to hook it all up to prevent the new system from ruining the speakers. Something about that Nissans have a special stereo system that isn't compatible w/anything else.
    I just want to replace my broken stereo w/something that can play radio, CDs, and has a USB adapter if possible. Nothing fancy, nothing expensive.
    Anyone have any suggestions? Do I really have to get special wiring, or would a certain type of replacement stereo just fit in nicely w/no modifications?
    Thanks,
    Tavia
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Don't see any reason why you can't just install a new head unit and speakers and bypass the factory system using new speaker wires.
  3. simple man
    simple man Member
    Bunnell,Florida
    I'm sure you can get a stereo from Walmart, or similar store, that will fit perfectly in your truck. They are usually set up for 2 or 4 speakers. If your Nissan has more speakers, just use 4. Shouldn't be anything complicated, but I have been wrong before!:)
  4. maverick1970
    Missouri
    Just a thought, go to www.crutchfield.com and select Outfit my Vehicle and see what comes up.
  5. svthauln
    svthauln Member
    Mounds,Ok
    1972 maverick
    Does it have Bose
  6. maverick75
    You might have to run new wires for the speakers like mentioned earlier. And they sell adapters to make the power supply plug and play.
  7. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    yeah, don't do like I did once and cut the plug off and try to wire it like the old days....get the adapter. Crutchfield is probably best for the diy'er.
    Good luck.(y)
  8. MaverickLVR
    MaverickLVR takes longer then you think...
    Grand Rapids, Michigan
    1976 Maverick Stallion, 1967 Olds Delmont convertible, 1999 Harley FatBoy
    get the adapter for sure, but the trick on those is if the factory amp(s) is in the dash or @ the speakers. you can by pass the amps but if it's a componet system you would be best off replacing the speakers also.
    I guess the question is what is the need for a new head unit? if it is just an upgrade in features you be better served finding what you want on rbay or in a junk yard and keep it factory. (imo)
  9. svthauln
    svthauln Member
    Mounds,Ok
    1972 maverick
    The problem is the Bose system has amp's for all the speakers and if you use a high powered headunit it will over power the speakers. So get the adapter and choose a low powered headunit and it will work fine.
  10. Craig Selvey
    Dittos to the Crutchfield suggestion.
  11. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Some of the newer cars stereo's are tied into the anti-theft systems. That may be why you were told it couldn't be replaced by just anything....
  12. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    Why not just spring a little extra cash and buy speakers too, then replace the whole thing? You'll get better sound and sometimes you can get package deals on a head unit/speakers.
  13. svthauln
    svthauln Member
    Mounds,Ok
    1972 maverick
    The pathfinder stereo does not have anti-theft
  14. lika
    lika Señor Comet
    IA
    comet 71
    best buy: they put in a decent stereo for not too much money and did the job well. my wife is so super happy.
  15. justin has a 74
    kentucky
    i got a pioneer from walmart and payed 130, best stereo i have ever heard!
