Pushbutton Trunk Popper
Discussion in 'General Maverick/Comet' started by Atzy1, Mar 31, 2002.
  1. Atzy1
    Atzy1 MMB Sporadic Participant
    Bremerton, WA
    '75 Maverick 4d (302, AOD, MSD, PST); '77 Maverick 2d (302, C4)
    Just in case anyone was thinking of this...I just put one of those electric trunk openers in. The kit was about $20 in JCWhitney.
    The solenoid that comes with the kit has a piston that moves in and out that is supposed to be connected to the trunk latch, but I found that the Maverick trunk latch is self-contained and only works when the key-part (with the little rectangular hole) is turned.
    To get the piston to work, I had to fabricate a little rod with a tab and pound it into the little rectangular hole, then route a wire to the piston such that when the piston pulled, it cycled the mechanism in the appropriate direction. If I had it to do over again I'd replace the tab with a little spool, and wrap the wire around it for a smoother turning action.
    It took about five hours to figure out all the mechanics, but it finally ended up working quite well. I hope this helps anyone who has plans to add this accessory in the near future!
    Happy Motoring,
    Atzy.
  2. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Atzy1,
    Any chance that you can post a pic of your engineering for future reference?
    Thanks
  3. Atzy1
    Bremerton, WA
    Sure...
    Sure. It's kind of "ghetto" but as soon as I take a picture I'll try to post it!
    Yours,
    Atzy.
