Radiator fan blade HELP
Discussion in 'General Maverick/Comet' started by LukeLikesComets, Mar 26, 2021.
  1. LukeLikesComets
    LukeLikesComets Member
    Canada
    1976 Mercury Comet
    Hey everyone, I recently took out my fan assembly to remove my shroud and when I was putting it back together the 4 bolts (below) wouldn’t screw in. Is the fan spacer meant to have to bolts screwed into it? Mine is smooth inside so I must’ve stripped it. Any help would be greatly appreciated thanks. -Luke [​IMG] [​IMG] [​IMG]
  2. LukeLikesComets
    Canada
    1976 Mercury Comet
    Here are the photos
  3. 71gold
    the bolts screw into the waterpump snout.
    LukeLikesComets likes this.
  4. Krazy Comet
    The fan spacer never had threads, bolts pass through it. Threads on bolts hold spacer & fan to the water pump.
    I'll leave some meat on bone, you're going to get additional replies saying to ditch the flex fan.
  5. LukeLikesComets
    Canada
    1976 Mercury Comet
    Thanks for the reply, for whatever reason the bolts won’t screw into the water pump either. The entry holes aren’t deep enough to grab onto the bolt
  6. yellow75
    Tillamook Oregon
    The spacer must not be seated on the water pump snout try to install a bolt by itself without spacer or fan to see if it threads in
  7. LukeLikesComets
    Canada
    1976 Mercury Comet
    Thanks, I tried that but the holes are not very deep and won’t thread the bolt in even by itself, how deep should the bolts be?
  8. LukeLikesComets
    Canada
    1976 Mercury Comet
    This is how much thread fits in the hole before being stopped, it doesn’t thread in either
  9. mojo
    Doesn't thread in - my guess - stripped out threads!
  10. yellow75
    Tillamook Oregon
    The spacer has turned use a screw driver to line up the holes between pump pulley and spacer
  11. LukeLikesComets
    Canada
    1976 Mercury Comet
    I’ll give that a shot thankyou!
  12. 71gold
    threads go all the way through the pump snout.
  13. LukeLikesComets
    Canada
    1976 Mercury Comet
    Thanks for all the help everyone! I just had to rotate the pump head and the holes lined up
    71gold likes this.
  14. yellow75
    Tillamook Oregon
    I knew you could do it and I will bet you are back here to ask more questions, feel free to ask
  15. LukeLikesComets
    Canada
    1976 Mercury Comet
    Thanks!
