Radio memory
Discussion in 'Technical' started by hbmmusic, Jun 25, 2016.
  1. hbmmusic
    hbmmusic Member
    Hey everyone- installing a new radio and I cannot find the wire used for memory (to keep the presets, clock, etc). At least, I can't find which one of these it is. I read that the cigarette lighter wire is blue w/ red tracer and supplies constant power- but for some reason, mine has the spliced female bullet terminal wire (foreground) leading into a joint rubber multi-connector (left-mid of picture), which seems to bring it to the wiring harness.
    I suppose my questions are: Is this the lighter/constant volt wire I want to use, and do I need to find some sort of connector that will work with this or do I need to just cut it from the rubber/plastic multi connector and splice it there?
    Thanks all! (Apologies if this is a common-sense-answered question!) this is on a 70 Mav, btw.
  2. Krazy Comet
    Blue with red tracer is the dash lights... Same for all Fords '60s to '80s...
    Constant hot is generally brown or maybe yellow...
  3. hbmmusic
    hbmmusic Member
    I haven't found a brown wire under the dash, and the yellow (black tracer, only one under there), which I believe would normally be the power wire, is, for some reason, spliced with the accessory line...
  4. Krazy Comet
    Well do didn't say what year but the '72 cigar lighter is lt blue and white...
  5. hbmmusic
    hbmmusic Member
    Yeah, I went back to my wiring diagram and saw its the same (it's a 70)- and connected To the emergency flasher. Which I suppose begs the question- where is the blue/white wire now?? I'm hoping the previous owner didn't remove it at some point.
    Thanks!
  6. hbmmusic
    hbmmusic Member
    Alright, I got it. The thing was bundled up underneath the ashtray, essentially. Blue w/ white tracer, as the diagram says. It's got an L female terminal on it.
    Thanks for the help!
