rear axle tag
Discussion in 'General Maverick/Comet' started by Pete21136, Nov 7, 2023.
  1. Pete21136
    Pete21136 Member
    maryland
    1972 Comet
    My 1971 Comet GT axle tag reads WDW AA. My master parts catalog only goes up to 1972 and this code is not listed. The center hub on the rear axle flange is a larger diameter than the front hub, so that stock Ford wheels will fit on the front but will not seat against the axle flange on the rear. I am assuming that the rear has been changed at some point to a later model. If so, in what year did they increase the size of the rear axle flange hub, and will earlier axles work in this housing?
  2. dyent
    dyent Member
    vancouver bc
    Rear axle hub sizes with our Mav/Comet where 2.43" for earlier, I think up till around 73? Had 3 "holes" and later where 2.78" with large oval hole. Axles should interchange as they where all 28 splined.
    David
    Acornridgeman likes this.
  3. Acornridgeman
    Wisconsin
    Pete, you didn't mention if 4 lug or 5 lug.
    This is for 8" housings:
    You can swap around any year of 5 lug with a 5 lug housing - and any 4 lug axle with another 4 lug housing - but you cannot swap around 4 lug with 5 lug axles, the housing bearings are different.
    The bigger hub holes came around the same time as the disk brakes - 1974 ish.
    TeeEl likes this.
  4. Pete21136
    Pete21136 Member
    maryland
    1972 Comet
    Thanks. My axles are 5 lug. Now I need to find a pair of early 5 lug axles.
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    TeeEl, Krazy Comet and BruceS like this.
  6. Pete21136
    Pete21136 Member
    maryland
    1972 Comet
    Thanks
  7. Pete21136
    Pete21136 Member
    maryland
    1972 Comet
    the bigger hubs are 1975 and up. I need 71-74 smaller hub non disc brakes
  8. Pete21136
    Pete21136 Member
    maryland
    1972 Comet
    sorry 5 lug
  9. f4294v
    f4294v Member
    Dallas
    73 comet
    Is the material to have pilot turned down ? Axles usually have a center drill location that could be held by tailstock in lathe.
  10. dyent
    dyent Member
    vancouver bc
    Yes, axle hub could be turned down. I forgot that this is what I did with mine, when I reused my 74 axles, removed the wheel studs and bearings, then mounted in lathe chuck via the bearing surface, trued up wheel mounting face. So the same could be done with center hub, if he wanted to turn its OD down from larger 2.78" to 2.43".
    Regarding the "center pilot" holes on each end, providing they are not damaged, can also check for any axle twist......
    David
  11. TeeEl
    TeeEl Senior Member
    Colorado
    '73 Ford Maverick Resto-Mod
    Should be'74 and later. 1974 was the year front disc brakes became optional on Mavericks/Comets, which would have larger hubs than the drum brakes...
  12. Krazy Comet
    Not that it applies to most Maverick but, hubs/spindles increased in size from 1969 to 1970. TRUE 1970 has larger front bearing, spindle & hub/wheel opening. This has zero to do with disc, my '69 Cobra & Fairlane has smaller wheel centers than my '72 Comet. Or at least did, when I swapped to disc brakes on Comet, I used smaller '69 Torino spindles. I'm not familiar with anything '74 newer, if they increased its the 3rd time.
  13. dyent
    dyent Member
    vancouver bc
    He is really inquiring about earlier axles with smaller 2.43" hub, so he can use his Ford rims........
    David
  14. Craig Selvey
    1974 model year is when the larger hub was started.
    Probably a lot easier to just find wheels.
    TeeEl likes this.
  15. Pete21136
    Pete21136 Member
    maryland
    1972 Comet
    Found a pair of early small hub axles this week, Installed with my 68/69 GT wheels.
    Krazy Comet and dyent like this.
