Rear vent window install question
Discussion in 'General Maverick/Comet' started by leeinphx, Jun 26, 2023.
  1. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    So I've starting reassembly on the '75. Got the headliner in and started looking at putting in the rear vent windows. Have new rubber seals for them, but trying to figure out how to install that seal. Does it just slide in place, or should you put some trim adhesive on it to keep it from pulling down in the corners like I see on so many?
    I've got them warming in the sun so I can try to get them to pinch into the corners.
  2. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    OK, got it. The ones I have are a little oversize so they fit very snug around the opening.
  3. Acornridgeman
    Wisconsin
    Yes, you answered your own question. They just go onto the pinch weld snuggly - no adhesive is used.
