removing window cranks
Discussion in 'Technical' started by mav302, Jan 21, 2013.
  1. mav302
    mav302 Member
    Baxley,Ga
    1970 ford maverick
    Kind of embarassed here...i cannot figure out how to renove my window cranks in my 70 maverick...do they just pop off or what?
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    There's a screw in the center of the crank on my 73, I would assume a 70 would be the same though.
  3. mav302
    mav302 Member
    Baxley,Ga
    1970 ford maverick
    The centwr is solid...no screw there and the center doenbt look like it pops out
  4. Paul Masson
    1971 Grabber
    There is a Phillips head screw hiding under a very thin (read: bendable) cover that is held in place with adhesive. Gently pop that off the center of the handle and you will have access to the screw. I believe these covers disappeared in '73.
    I was able to re-install my covers without adding any more adhesive. This stuff stays tacky for a long time. I used a small pick to pry the cover off.
  5. mav302
    mav302 Member
    Baxley,Ga
    1970 ford maverick
    Holy cow...ur the man....the little silver cover peels off...it looks seemless until u start to try to peel it...thanks!
  6. Paul Masson
    1971 Grabber
    No worries. If you bugger them up, you can live without them. If you can't live without them, they are still available for about $1.50 each.
    AutoKrafters sells them in their Maverick catalog on pg.15. Most other Mustang/Ford vendors would also carry them.
  7. mav302
    mav302 Member
    Baxley,Ga
    1970 ford maverick
    i managed to get em out without damaging them...just used a really sharp pointed knife
  8. Shari
    Shari Member
    Effie MN
    Glad you asked this question because I couldn't figure it out either :) I was taking the door panel off and had to stop and come in to search the forum for the answer :)
