Setting the Distributor
Discussion in 'Technical' started by bigmavman, Oct 19, 2003.
  1. bigmavman
    bigmavman Member
    Santa Maria, California
    1973 Maverick LDO w/ 302ci
    Is there anything special I need to do went setting my distributor in my 302 maverick? I pulled it to make the removal of my manifold easier. Now it is time to put it back together and need some help.
    Thanks
    Red
  2. inline6
    inline6 Member
    setting the dist.
    bigmavman,as long as you didn't move the crank,just line up the rotor,to point at #1 on your dist.and drop it in.make sure that you compensate for the travel on the cam/dist. gear.if the crank got bumped,have a bud turn the crank bolt with a ratchet and socket,(remove the #1 sparkplug)while he is turning the crank,feel for pressure,(enough to push your finger up)that should put your #1piston tdc or pretty close on the compression stroke.then drop in your dist.someone else on the forum might have a easier/different way but this is the easiest way i have found(for me).i also put a little assembly lube on the dist.gear.good luck with your project...chuck.
  3. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    bigmavman: Where in California are you located?
    -Corbin
  4. Scotty P
    Scotty P Member
    santa rosa, ca
    INLINE6 is correct ONLY if you shut it down at TDC. Look at the timing marks on the dampner. You need to have the timing pointer at TDC on the commpression stroke before you line it up on #1 and drop it in. I pull the #1 plug, wad up some toliet tissue and put it in the plug hole. Then turn the motor over by havd (breaker bar or torque wrench work wekk. When the tissue "pops" out and the marks line up, then do as above. If you get a popping back through the carb, don't panic! Turn the distributor/rotor 180* God luck.. Scotty
  5. inline6
    inline6 Member
    good call scotty p,i should have worded that one a little better!
    as the body ages,so the mind drifts!
  6. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    If the motor is not moved, it goes back in at the same point it came out. You needed to look at this before taking it out and write it down or mark the rotor to housing position to return it to the same location.
  7. bigmavman
    bigmavman Member
    Hey Corbin I am located in Santa Maria on the Central Coast. That is between San Luis Obispo and Santa Barbara.
