Smooth/Rough/Smooth—driving me crazy!
Discussion in 'General Maverick/Comet' started by Renton5, Oct 2, 2022.
  1. Renton5
    Renton5 Member
    Van Nuys, CA
    1971 Maverick, 200 engine, 2dr
    There’s an episode of the original “Star Trek” called “Spock’s Brain”, in it, Dr. McCoy puts on a thinking cap and knows how to re-attach Spock’s brain—I wish there was something like that for Mavericks with the 200!
    The idle is rough, then smooth, rough, smooth…eventually the engine stalls. Pertronix ignition and coil. I know the alternator is a bit weak. My uneducated opinion is it has something to do with the fuel delivery/carb. Vacuum hoses look good, sprayed the base of the carb, no change. Pressing on the pedal a little made it rougher, so I eased off, kept it steady pressure, then the alternating speeds idling occurred.
    No AC, no power brakes.
    This is a link to a YouTube video I made. Turn up the volume a bit to hear the alternating idle.
    If needed, I can make a better video.
    Thanks Everyone!
  2. ike72com
    ike72com Member
    Charleston SC
    you could at least open hood and shoot video!!!
    i,d start with a compression check. then reinstall with new plugs and wire. new fuel filter and a carb rebuild. Routine maintenace stuff!
    plynch likes this.
  3. Renton5
    Renton5 Member
    Van Nuys, CA
    Agreed.
    I’ll shoot a better video on Wednesday.
  4. TeeEl
    TeeEl Senior Member
    Colorado
    '73 Ford Maverick Resto-Mod
    The solution is a V-8 swap...
    plynch likes this.
  5. ike72com
    ike72com Member
    Charleston SC
    I,m recalling i had problem simular to what you,re describing. I dont drive my truck with holley carb much.
    My needle and seat in carb was all gummed up opened or closed from dried ethonol fuel. This cause a fuel starvation or flooded condition. it ran erractic and eventually shut down.
    I suspect same going on with yours.
    Russell likes this.
