solid motor mounts
Discussion in 'General Maverick/Comet' started by PINKY, May 5, 2002.
  1. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Does anyone know where I can get solid mounts for my Mav.??
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Don't know the answer to this one, but I will pass along a mod I did to mine when the mount separated.
    I drilled a hole straight through the center of the mount, both pieces of steel and the rubber bushing. The hole was 3/8" if I remember right. Then I took a 3/8" grade 8 bolt long enough to make it through the mount and fastened it with a nylon lock nut. Don't tighten it more than snug. Now it will be snug, yet still have the rubber bushing for vibration control unlike a solid mount.
    Just a thought
    Dave
  3. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Dave,
    At the recent Fun Ford Weekend in Houston, I noticed there were a couple of Mavericks with mounts modified in the way you described.
    Me thinks I'll do the same (can't hurt!)
    Thanks,
