nothin like fixin one problem and havin another. 1997 4x4 5.0 explorer sqeakin on the drivers side in the front end. i have spraid wd40 everyware and it still sqeaks. do you think the bushings could be worn out ? there is no place to grease anything..........................
Have you tried to apply a light coat of lube to the sway bar bushings? I have had to REMOVE them and coat them before...
no but i spraid the hell out of the bushings with wd40. do you think i should wip it off and try grease ????????????
Spraying doesn't help. You need lube on the area that makes contact with the bar on the inside. I use grease that does not affect rubber, like brake caliper grease. I posted the thought about the bj cause i'm thinking it's more likely squeaking there.
