stalling...
Discussion in 'Technical' started by Warlock_Mav, Jan 25, 2003.
  1. Warlock_Mav
    Warlock_Mav Member
    Mason, Illinois
    I have a 70 mav w/ a 72 200 and heres my dilemma: My car has a new rebuilt carburetor, the timing is great, it accelerates with out hesitation, and pulls great to about 3000-3200 rpm. Then it all of a sudden falls on its rear. So ive pretty much ruled that its my ignition system mis firing, or ive got some wicked stuff goin down w/ the valve train. The ignition system has been converted to the pertronix solid state. Any ideas, or other possibilities?
    Thanx for any info you may be able to provide,
    Kyle
  2. Mavaholic
    I'd check the float level first. Probably too low.
  3. Old Guy
    Old Guy Member
    Stalling
    I agree on the float level, also some other things to look at would be fuel pressure from pump, total advance curve, coil voltage and yes, valves being to tight etc. Try to eliminate each source of potential problems one at a time and should be able to find the gremlin.
  4. Earl Branham
    Lugoff, SC
    Stock fuel pump will do that too. Put a high volume Holley or Carter pump on it, and it will go away, if that is the problem.
    Earl
