Stock 250 Carburetor Swap Questions
Discussion in 'Technical' started by BananaMaverick, Apr 12, 2017.
  1. BananaMaverick
    BananaMaverick Superior Maverick
    Vermont
    1976 Ford Maverick
    My 1976 Maverick has its original carburetor. I have been having a hard time getting the car to run properly and adjusting the air/fuel screw doesn't perfect it. I can unscrew it almost all the way out and the idle keeps increasing. I have notice power decrease and rough idle. It intermittently pops softly. I have done a couple carburetor rebuilds and haven't seen any positive results. Should I get a rebuilt original carburetor? I have been looking at Carter RBS carburetors, are they worth getting with a stock 250?
  2. 71gold
    first I would find the problem and fix that...:yup:
    a guy brought Harold a carb yesterday that he just paid a Guy $400 to build, it wouldn't idle. he called the builder and was told..."we ran that carb on a car, you have a vac. problem" and the Guy hung up the phone...:huh:
    Harold pulled the top off, the gasket was skewed and the acc pump seal was flipped backwards...new rebuild kit will be in tomorrow.
    point is...this Guy paid $400 for a carb that needs to be rebuilt...:slap:
    you building it or buying a rebuilt one...if it's not built/installed right to start with it want be right on the car.
  3. Krazy Comet
    A carb rebuild is more than just replacing a few parts... Yeah you can get lucky and toss a kit in one and it run perfectly, or at least better than it did(could run worse)... Back in the day a kit would generally fix one, now often there are other issues...
    A proper rebuild starts with a "squeaky clean" cleaning and inspection of all passage ways and air bleeds, some of these are so small a broom straw would not fit into... Also one needs to determine the route of said passages and be sure they are open... Often they intersect another passage at a angle so there could be a plug the blocks the original opening... I try not to deal with the plugs but if there is a blockage that can't be cleared with Berryman or other carb cleaners/dip, it needs to be pulled out and cleaned from that area...
  4. BananaMaverick
    Vermont
    1976 Ford Maverick
    My car overheated really bad (300+ deg) after I took it to a shop. I melted every gasket in the carburetor and others around it. It melted the wire harness for the choke. I'm concerned if the carb is damaged/cracked or if the throttle plate bushings are no good. That's why I've been looking at new carbs.
