suspension question!
Discussion in 'General Maverick/Comet' started by Jake, Jun 21, 2002.
  1. Jake
    Jake Member
    Fayetteville, NC
    73 Maverick Grabber
    Hey folks, anybody figure or know for sure if 1972, or abouts, mustang suspension parts are interchangable on any of our Mavericks or Comets? The upper control arms, springs and perches all look as if they would work and are alot cheaper. Hope to hear from you folks. Thanks
    Jake
  2. jeremy
    jeremy I build t5's
    Corona, Ca
    I believe they should, I talked with someone a while back about this. I have the front end suspension off of a 73 stang with disc brakes. I have not put it on yet, but after I finish buying my house I plan to put that front end on.
  3. Jake
    Jake Member
    Fayetteville, NC
    73 Maverick Grabber
    Thanks
    Thanks jeremy, I may get some components soon and try a few to see what works. Let us know when you get to your project! I'll let eveyone know if I have any luck also.
    Jake
  4. Craig Selvey
    Yes....I have 1972 Mustang parts on the front of my 1972 Maverick
  5. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    suspension help
    A 72 Mav has the same suspension as a 70 stang does.
  6. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Do sway bars interchange or are the Mustangs wider? They probably are, but it would be cool to have the extra options with all the Mustang aftermarket sway bars out there if they did fit.
    -Corbin
  7. Jake
    Jake Member
    Fayetteville, NC
    73 Maverick Grabber
    Thanks for the input everyone! I'll be doing the mustang thing. It's alot cheaper than Maverick specific places. Gotta save when we can. It allows for more POWER later!
    Jake
  8. JC13
    JC13 Loyal To The Maverick
    Colorado
    1973 Maverick
    I once bought a 1 1/8" anti-sway bar for my mav from a 68 stang. It is a good 3 or more inches too long. I'm sure that this part from a 70's mustang would be too long as well. I guess the control arms and bushings and such would work.
  9. rickyracer
    rickyracer Member
    Central Nevada
    swaybar
    The swat bar is different and a Comet one is the only one I've found that works also.
  10. phflimflam
    phflimflam Member
    Texas
    1974 Mercury Comet 4 dr, 250/6 soon to be Harshly upgraded!
  11. Corbin Johnson
    Thanks guys. I was pretty sure that they wouldn't work, but one can always hope right? Thanks for your time.
    -Corbin
