Swapping a 289 to replace a 250 l6
Discussion in 'General Maverick/Comet' started by JosephBrand, Feb 3, 2022.
  1. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
    thoughts and tips would be much appreciated
  2. 71gold
    thought...why a 289?
  3. Krazy Comet
    Why not?????? Wanna list the differences that'd affect a swap of 289 vs 302? Possible bellhousing bolt pattern difference, timing marks/pointer on opposite side of engine, water pump inlet also on opposite side. A '68/'69 302, has the timing mark & water pump inlet issue.
    Here's most of the info using 302 from '70 up.
    http://mmb.maverick.to/resources/for-those-of-you-interested-in-doing-the-i-6-to-v-8.83/
  4. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
    Krazy Comet likes this.
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Don't get me wrong, the 289 is fine, but the 302 will do.
  6. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
  7. Krazy Comet
    Ahhhh Blue Print Engines, I have one of these setting in my garage...
    I bought mine from a friend that pulled it out of a Mustang he is restoring for SCCA racing, big engine not allowed. Minus oil pan & carb, otherwise it's complete with balancer, has approx 2000 miles... No it doesn't have the ugly ass GM dist, has one similar to Ford.
    https://blueprintengines.com/produc...k-ford-dressed-longblock-carburetor-bp3474ctc
    JosephBrand likes this.
  8. Shorty
    Shorty Member
    Lafayette, In
    I running a Blueprint Engines engine too. I bought my 347 long block direct from them because the machine shops in my hometown that I had used in the past seemed to have disappeared. Blueprint installed a front sump oil pan (in place of the dual sump the engine came with) and swapped to an early style timing chain cover for no extra charge. It runs fantastic with loads of torque.
    Bruce
    Krazy Comet and JosephBrand like this.
  9. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
    If I get the blueprint one I will be swapping valve covers for blue ones
  10. Krazy Comet
    But with the right bling, chrome is cool... No this isn't the 347
  11. mojo
    What the 347 going in?
  12. Krazy Comet
    Fairlane...
    Maybe a 331 for Comet.
  13. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
  14. BruceS
    BruceS Member
    Texas
    1973 Comet
    The 289 was a fine engine. It did it's job back in the day. The 302 is a more modern engine and would be the one I would choose after the 351.
    Jaybee and JosephBrand like this.
  15. Craig Selvey
    Just get the 6 cyl running first, and then ascertain what else the car needs before you start throwing things at it. :D
    74LDO, jasonwthompson and JosephBrand like this.
