Tallest rear tire?
Discussion in 'Wheels and Tires' started by cam1000, Sep 15, 2007.
  1. cam1000
    cam1000 Member
    Eastern North Carolina
    What is the tallest and widest rear tires anyone has had luck fitting on the mav with 14 or 15 in rims? Pictures would be great. We ran 14" rims on our first maverick strip car with 28tall by 9 wide m/t that did rub on the fender lips pretty good until we shaved them off, but it gave the rear wheel well a full look which is what i want to give the 74 a "drag" look. Any help would ge great .
    Cam.
  2. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    I am running 225/70 R15s out back.
  3. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    If I remember correctly I was running a 255/60 R14 ??? on the Blue maverick in my sig line but it sure has been a looooong time so don't quote me on that but it was something close to that none the less. I know they were really wide, not too tall and expensive as hell
  4. Scotty P
    Scotty P Member
    santa rosa, ca
    I am running a 275-60-15 Drag Radial and it fills the well fine.
  5. cam1000
    cam1000 Member
    Scott, do you have any larger pictures of your car with these on? And what rim/rear axle combo are you using?
    Thanks Cam
  6. Scotty P
    Scotty P Member
    santa rosa, ca
    Here you go. This is before paint, lowering, markers removed etc etc etc
    The rear is out of a Ranchero and is only 1/2" shorter than stock. Rim size is 8.75 with 4 5/8" BS
  7. cam1000
    cam1000 Member
    Scott,
    Thanks for the pictures. Before you modified your lips how close were they to your tires? The Blue looks very good on your car btw.
    Cam.
  8. Scotty P
    Scotty P Member
    santa rosa, ca
    The lip was less than 1/8" away and would rub on even the slightest body roll. Thanks, I like the color as well.
  9. starsky74
    starsky74 Technician
    Hackberry Louisiana
    what year ranchero?????
  10. j miller
    Polson, Mt
    i am running 275/60/15 on the rear too. i did have to roll the fender lip for clearence. click on the camera icon under my name for pics
  11. rayzorsharp
    Same here! :)
