time to rebuild the 302
Discussion in 'Technical' started by pinjimin, Oct 20, 2002.
  1. pinjimin
    pinjimin New Member
    vancouver canada
    75 grabber
    well guys this is my first time on the board and i need some help. i recently killed the motor in my 75 mav. i've decided to rebuild. i need some advice on what to use? (pistons, conecting rods, cam ect.) i'm a 2nd-3rd year apprentice so this will be my 1st rebuild. now i don't want to go overboard with horsepower. i'd just like to step up a little bit from stock. now assuming the crank is not to bad should i have it machined or get another one. (will this one handle the upgrades?) thanks for any help.
  2. mark_b
    mark_b Member
    western PA.
    73 all original 302 2d red blk int. 72,302.2dr. green and 71 200ci. 2d green
    The first thing you need to find is a good machine shop that can cunsult you on how to set up and recondition your block and heads & cranks for your motor.
    The second thing you need (If your new at rebuilds) Is a good book that can take you step by step.
    The book I have is by Tom Monroe "rebuilding small block fords"
