Timing Adjustment
Discussion in 'Technical' started by NewMaverickGuy, Oct 13, 2018.
  1. NewMaverickGuy
    NewMaverickGuy Member
    Birmingham, AL
    1970 Ford Maverick
    How do I loosen the distributor to adjust ignition timing? It's an autolite distributor on an I6 200.
  2. 71gold
    there is a bracket and bolt where the dist. goes into the block at the base of the dist. loosen the bolt and you should be able to turn the dist.
