Tires and rims
Discussion in 'General Maverick/Comet' started by 76 Mav, Sep 15, 2002.
  1. 76 Mav
    76 Mav Reformed Camaro junkie
    Cobb County Ga.
    76 Mav , 70 Galaxie ,04 F350,03 Mustang,03 F150
    Whats the widest tire i can put in the rear without any mods ?
    I was thinking about moving up to a 15" rim ( i already have a decent set of rims) but i dont want to mess up my speedo... any suggestions?
  2. mavman
    mavman Member
    Arkansas
    glad to see another Camaro junkie's blood turn Ford blue! I run 255/60-15's on the rear, 4" offset 15x8 drag stars. On the race car, we run 28x10.5-15's on 15x9 progressives, also with 4" offset. The drag car needed some massaging, but only on the inside wheelhouse. The street car needed some "minor" rolling of the outer fender lip---but only needed it to keep it from rubbing with passengers in the back seat. Hope this helps.
  3. grabber71302
    grabber71302 Member
    alberta canada
    maverick grabber
    i have had 15 X 10 mags on my mav! 275 60 15's.
    they rubbed only over hard bumps, but only cause my
    springs have lost the arc.
    but now i run on 15 X 8 mags with 255 06 15
    hope this helps!
    kris
  4. Charlie
    Charlie maverick.to/grabber
    Indianapolis, IN
    1970 Ford Maverick Grabber (Modified)
    Use the search function, I know there is some good info already on the board :)
  5. Jesse
    Jesse Member
    Langley, BC, Canada
    1972 Maverick Grabber 302
    For those of you who have used 275/60/15 tires, what size and offset rim did you use? I can get a deal on some of these, but need to know what will work. Thanks.
