Tires Nuts Torque?
Discussion in 'General Maverick/Comet' started by mavzac, Dec 1, 2022.
  1. mavzac
    mavzac Mexican Maverick Owner
    San Luis Potosi, MEXICO
    Maverick '77 302V8
    Someone knows what torque should to be applied on the tires nuts??, I bought a set of tires in Costco and they said me that they don't have this specification for Ford Maverick '77 and maybe they could not installed without this measure. Company Policies!
    Thanks in advance!!!!
  2. Acornridgeman
    Wisconsin
    The old rules around the shop "back in the day"
    85ft lbs for steel wheels / 70ft lbs for mags
    Give them these numbers and it will get you out of their doors. When you get home - check and retorque them.
    71gold, RMiller and mojo like this.
  3. mavzac
    Maverick '77 302V8
    Thank you!!! I appreciate it!!!!!!
  4. TeeEl
    TeeEl Senior Member
    Colorado
    '73 Ford Maverick Resto-Mod
    There are no nuts on your tires. They are on the wheel studs. I torque mine to 90 ft.-lbs.
    Anywhere from 85 to 100 should be fine...
    Shorty and Krazy Comet like this.
  5. mavzac
    Maverick '77 302V8
    That's right!, on Wheels!!!:facepalm:
    TeeEl likes this.
  6. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    You'll want to recheck them after about 50 miles, especially with alloy wheels. It's rarely an issue, but once in a while it will be. For that purpose you don't have to get real fancy, just give them a quick jerk with a lug wrench to make sure none of them are loose. Use a star pattern as that's the norm with lug nuts to ensure even torque and lack of distortion of the wheel and hub or axle end.
