TR7 flooding
Discussion in 'Other Automotive Tech & Talk' started by JHodges, Jul 4, 2009.
  1. JHodges
    JHodges thumper
    Dora Alabama
    The 351w in the tr7 wants to foul plugs extremely bad. The plugs are black so it is not burning the gas. The motor is basically stock internally it has a 600 vc holley on it. I believe it is not getting enough fire. I plan to swap a blaster 2 coil on it tomoorow. It has duraspark ignition on it. Any more ideas on what it could be
  2. Jamie Miles
    Carb jetted to rich.
  3. PaulS
    Choke not opening....
  4. JHodges
    JHodges thumper
    Dora Alabama
    we have the choke open at all time
  5. 71gold
    did it ever run right or is this something that just started?
  6. JHodges
    JHodges thumper
    Dora Alabama
    it did the same thing with the 650 that came on it. I'm thinking weak fire
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Might have to much fuel pump pressure?
  8. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I was going to say check the float levels, but if it was doing it with the other carb, I have to agree it might be too much fuel pressure. What kind of pump does it have? Does it have a regulator? Weak spark might cause it to start hard, but it should still burn whatever gets in the cylinders.
