trans fro 74 mav with 300-6
Discussion in 'Technical' started by maverickdad, Jul 22, 2003.
  1. maverickdad
    maverickdad Member
    Martinsville Indiana
    1974 maverick
    I have a 1974 maverick with a 300-6, bored 40 over with a hi-po cam, hi-po head, offenhuser intake with a 450 cfm 4-barrel carb with ram air. I have a 4\11 posi track rear end under it.
    Hears my question. I want to put a 3-speed auto trans with overdrive in it. What kind of trans do I need and what can I get it out of. The engine is out of a 1988 truck. I talked to someone on your site about this befor and they told me what I needed and what I needed to set it up.I think they said a trans out of a older lincoln or there were a couple others. I beleive I neded an special kit to set the linkage system up with. Can you point me in the direction for the things I need?
    Thanks.
    Steve.
    success@reliable-net.net
  2. MustangSix
    MustangSix www.fordsix.com
    Any AOD or AODE that fits a small block Ford will also bolt to the 300. You need a 164 tooth zero imbalance flexplate with an 11.4" bolt pattern from an automatic 300.
    From there, it's the same drill as putting an AOD behind a V8: TV cable, crossmember, shifter, cooling lines, driveshaft.
  3. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    The AOD from a Lincoln Mark VII 88 up or one of the big cars will be the better units to use.
    I think you will have a lot of low and mid-range torque with your setup.
    Sounds like it will be a blast to drive.
    I tend to like lots of low and mid range torque.
    4.11 rear might be a tab low but thats up to you after you live with it a while.
    My daily driver is a Mark VII with a Baumann AOD shift kit and blown 5 L engine and 3.27 gears.
  4. maverickdad
    maverickdad Member
    1974 maverick
    ADO on 300-6
    Thanks for the info guys. Do you know this answer by experience?
  5. MustangSix
    I had an AOD from a 91 Lincoln hooked to the 250 in my Mustang. The same setup would apply to a 300. I drove the Mustang this way for five years and it was a nice cruiser. I would invest in a good shift kit, at a minimum, to firm up the shifting.
  6. maverickdad
    maverickdad Member
    1974 maverick
    thans on the 300-6
    Thanks Jack
    I may get in touch if I have any trouble.
    Steve
