I'm having a brain fart this morning, is this the correct tool for removing valve springs off of e-7 pedastal mount heads with heads still on car? http://www.autozone.com/autozone/ac...or/_/N-4aow?counter=7&itemIdentifier=2052_0_0_ Thank you :Handshake
If you are going to have the head off then use the "C" clamp type of compressor. If the head will remain on the block then you can use the one you show.
I have one of these: http://www.proformparts.com/product...OR_FOR_3_8_7_16_ROCKER_STUDS_/category_id/171 Works like a dream, I just had to make a stud to screw into the E7Te head.
