Versales 9" rearend
Discussion in 'Technical' started by Allen Small, Jan 3, 2003.
  1. Allen Small
    Allen Small Member
    Cannonsburg, PA
    73 Grabber/V8 and 72 V/8 grabber
    I was wondering if any could give me info on swapping a Versales
    9" rearend from a Lincoln into a 73 maverick. Are the rearends
    a match and just bolt in or does the unit need to be narrowed to
    to the original stock 8" units width before installing. Any help
    is greatly apprecaited.
  2. John B
    John B Member
    Ontario, Canada
    '73 Mav
    Allen; There are a number of sites with info and even pics on how to do this swap. I'm including a link to one of the better ones by our very own Charlie Ping. I'm confident that you will find this helpful. Also try doing a search using "Versailles differential" or such words. Good luck. John B.
    http://www.geocities.com/cping3/lincolnversailles.html
  3. Allen Small
    Allen Small Member
    Cannonsburg, PA
    9" rearend
    John,
    Thanks for your response. all the info is very helpful. I will let you know how it all comes out. Again thanks.
    Allen Small
    73 Grabber:)
