Have replaced regulator, alternator, etc. Turn on headlights and they pulse bright, dim. Also show's on ohm meter, on any hot wire, any idea's?
Check your ground real good. Probably replace headlight switch, When you put the meter on, was it at headlights? With engine running an no lights turned on, check batt voltage. Also, do headlights dim without engine running?
It may be in turn signal assembly do yourself a favor and unplug the flash as well........ Past that i would also look for grounds!!!!
I had a brand new alternator do that also before on that GMC of mine. It went out, put a new one on... it pulsed for a bit until it bit the dust before i could remove and take it back (less than a week) Matter of fact, I changed it out at your house with Junior.
