not sure how long of shank i need for my lug nuts?the holes are about 1 1/2 inch deep. 1/2 or 3/4? i iwll be using open lug nuts for drag racing. thanks john
http://www.jegs.com/i/Detroit-Wheels/306/5120-O-4/10002/-1?parentProductId=756707 you need the long shank ones. 1/2 and 3/4 are not long enough
You will need 3" wheel studs and you will have to take one off to determine the size of knurl you will need to fit in the axle hub, if this is what you are asking. And then you will need the lug nuts that are posted above
