Went Muddin
Discussion in 'Other Automotive Tech & Talk' started by Ford Guy, Aug 4, 2009.
  1. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    Well yesterday my friend in his 2007 F150 on 35's and me in my 1990 F150 on 33's decided to go muddin. It was goin well until I hit this big nasty hole that just swallowed my truck up. My friend then tried to pull me out in reverse, but with no luck. As he is turning around to pull me out in a forward gear, he gets caught up in a deep rut and then he is also stuck. Luckily, our friend came by in his Grand Cherokee and he first pulled out my friend then they both hooked to me and my truck was finally free after 3 hours. This was my first wheelin trip, and I enjoyed it even though I got stuck pretty good.
  2. JHodges
    JHodges thumper
    Dora Alabama
    looks like fun. When I finish college one of the things I want is a wrangler on 35's.
  3. 73rustymav
    73rustymav Member
    clear lake, califorina
    First car in my life 69.5 maverick built 250 inline swap. 73 maverick RIP
    wow looks loke fun.... all you need is 4 more inches of lift and 40's:thumbs2: that will solve your problem
  4. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    Yeah I really want to lift it with 35's, but I think a locker out back and a good LS up front will help out tremendously with a good set of 33's. Right now its got open diffs front and rear and bald mud tires.
  5. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    My F150 has 31s and a lift with dual positrack, it pulls like an ox on meth. Man it's great to bash through a good mudhole once in a while.
  6. mean_maverick
    wow, that truck is in great shape! (y)
  7. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Yeah sucks muddin in a 2 wheel drive get the locker first that way you atleast have a 3 wheel drive. Thats one advantage jeeps have over fords alot of them came from the factory with atleast limited slip standard.
  8. david_h_30170
    david_h_30170 Member
    Roopville,Ga
    1973 2 door v8
    Man that looks fun.:yippee: I used to take my Ranger out muddin, got tired of all the cleaning and changing the fluids and packing wheel bearings.
  9. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    kiss every freaking seal good bye, along with the bearing surfaces they protect. (ex-Paragon regular)
  10. sierra grabber
    sierra grabber Certifiable
    northern nevada
    yeah mudding can be fun but if you use it for driving also then you need to at least hose down every part immediately afterward and check stuff regularly. also have money for the parts you break... just like boating it turns into a money pit.
  11. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    Yeah we went to the car wash right after we got off the trail to clean the trucks, especially the undercarriage.
  12. grago1978
    grago1978 Member
    TN
    1970 Maverick, 302 AOD
    Makes me wish I hadn't sold the old Bronco. 87 Big Bronc on 6" lift and 35's. Miss that thing.....
  13. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    The pics don't really do it justice, but it was deep enough to get my truck stuck. What happened was I went into it straight, like in those pics, but there was a rut or hole underneath that threw the truck sideways. Those pics are after my buddy pulled me straight.
  14. JHodges
    JHodges thumper
    Dora Alabama
    I am planning on getting a 4x4 like yours and wondered how well it did. The 69 would get stuck on wet grass so anything is an improvement.
  15. markso125
    markso125 Member
    Lewiston Ut
    Had a 72 shortbed, with a 360 and a 3 speed with a granny low, thats one of the best four wheel drives I had.
