What heads are you using?
Discussion in 'Technical' started by Grabber5.0, Feb 5, 2003.
  1. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    For those of you that have modified 302's in your Mav's, what heads are you using? Just wondering what people have used and what they thought of them. I don't know if I can swing aftermarket performance heads any time soon, but I'd like to know what's good and what's not. I am looking for the 250-300hp level. Probably no chance of doing that with any stock head without lots of maching $$, except maybe GT40P's which have special header problems due to the plug angle.
  2. bmcdaniel
    bmcdaniel Senile Member
    I'm running GT40P's in mine with the same headers I used for the windsor heads.
  3. bmcdaniel
    BTW, if your interested, I still have the heads that the GT40P's replaced, '70 351W's w/ ported valve pockets & exhaust ports, 3 angle valve job, ARP rocker studs, Comp Cams roller tip rockers. Not many miles. About all they would need is hot tanked and some new valve stem seals, maybe positive type seals like the newer heads use.
  4. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    e-mail me
    todmeg@aol.com
    where is york in relationship to nj? i may be interested in those heads!
  5. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Haven't tried them yet
    I had my 68 58cc heads built for my 68 block:
    1.84 intake
    1.54 exhaust - ported
    Hi-Po springs and teflon seals
    Guide plates and screw in studs
    I'll be using them with Speed-Pro flat tops, Comp-Cams 270H Cam (.500 lift) and Comp-Cams Roller-tip rockers. Hooker Competition headers for exhaust.
    I'm hoping for 9.5:1 or 10:1 compression and over 300 horsies and a decent idle.
    Will be a little while before I get to fire it up.
    http://homepage.mac.com/dmhines/PhotoAlbum6.html
  6. Will
    Will I
    Waco
    74 2door - Small bumpers, 5.0 EFI, Tremec 3550, disc brake 8.8,MII front end, boosted
    E7's right now
  7. Warlock_Mav
    Warlock_Mav Member
    Mason, Illinois
    69 351W heads pocket and exhaust w/ polished intake ports... they will definitely support the 250-300hp (and quite possibly a lot more depending on your build-up) you want to make with out a doubt man.
    I gave 550 for mine... may have got robbed, who knows too late now.
    Kyle
  8. Mavaholic
    AFR 185's which have been ported out and milled. I'll let you know how I like them when I hit the track this spring.
  9. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    Victor Jr's w/ some titanium goodies and enough portwork to support about 750 horsepower!!!! :D
  10. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    All Ford Stuff.......
    I probably should have gone the aluminum aftermarket route...
    '70 351W heads
    Bowls cut, polished and ported on the exhaust side (gasket match), 1.94/1.60 Ferrea (sp?) stainless valves, ARP screw-in studs, guideplates, bronze guides, Crane billet roller rockers, Melling double valve springs...and milled to 53 cc's running hypereutectic flat tops with valve reliefs. Compression calculated at 10.5-10.6:1.
    I paid $75 for the bare head castings and I have just about $700 in parts and machine work in them. It was one of those situations where I started out with a $400 budget for heads and I let it get out of control. I probably would go with the aftermarket aluminum heads if I did it again. I feel that I got a deal on them for what it may have cost, the machinist did some other work for me and gave me a price break on machining.
    Seth
  11. CometGT1974
    Western NC
    74 Comet GT
    I"m with littleredtoy, I did the same thing that he did (almost word for word) except I started w/ 63 289 heads that cost me $125 and I had a guy that builds Busch Grand National motors do the work for me.....after all the smoke cleared I had about $1100 dollars total in the heads!!!:( I figured out real quick that I would go the aftermarket route next time!!! Even if you decide to work a set of old heads, send them to a company that does a shit load of them and you'll save some money.....some place like "Power Heads" (I think thats the name) These big companies can CNC port a set of old iron heads for less than someone can do it entirely by hand....and I don't care what anyone says, CNC porting is better then ALL hand portwork. Of course any CNC head will have to be blended by hand ,but the consistency of a CNC machine can not be duplicated by the human hand and die grinder!!!!
  12. Grabber5.0
    Kansas City, MO
    71 Grabber
    I'm seeing a patter here.. :D Sounds like I will be happier in the long run if I buy the aftermarket heads, probably the aluminum ones for the weight savings and cooling. I can get the RPM heads with studs for 529 or so each from jegs complete. By complete, I take it I just need to buy rockers and pushrods (which I have to buy regardless of which way I go)
  13. CometGT1974
    Western NC
    74 Comet GT
    Matt, I have a thread off of another site that you need to read.....i'l find it for you here in a minute....
  14. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    A.F.R 185's fully CnC ported 58cc with Upgrade Hi Flow race Valves, 1.530 O.D. springs,blend bowls all work done by A.F.R
    cost 1,577.76 with shipping takes them 3-4weeks
    I am in week 2 now :D Wan't There Number Matt
    http://www.airflowresearch.com/
  15. CometGT1974
    Western NC
    74 Comet GT
