What Machine Tools?
Discussion in 'Tool & Shop Talk' started by Comick76, Jul 21, 2009.
  1. Comick76
    Comick76 Grease Monkey
    San Angelo, TX
    76 Comet
    My Boss wants to get into rebuilding cylinder heads. I wouldn't mind it either for my own purposes. I know whats involved in rebuilding but, i want to get a good list of machining tools I would need. It's quite a task starting from scratch and I don't want to overlook anything. Any experienced help would be appreciated.
  2. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    get one of these
    http://www.sunnen.com/ProductDetails.aspx?ProductID=41&NavID=680
    and one of these
    http://www.dcm-tech.com/dcm_products/head_and_block.php#3810
    and you should be all set to go
    that is assuming you have the proper cleaning tanks.
    I have redone several heads on a bridgeport mill and it can be done but not quicly enough to make any substantial money off of it. If you are doing it for your personal use it is fine The machines I have given you links too have adaptors for different heads so setup time is 1/8th the time it would require on a bridgeport.
