what they dont tell you
Discussion in 'Technical' started by lordzero, Mar 30, 2003.
  1. lordzero
    lordzero Lord of Zero
    Eugene oregon
    1976 4 door I6, 1973 4 door 302, 1975 2 door I6, 1974 2 door 289
    so ive been doing these things with my brakes latley....and all of these web sites i learned off off never told me what happens if i don bleed from all of the tires....since my front bleeder nipples wont work....and i started to notice that most sites dont tell you the wrong way to do these things..just the way they say it works(wich can be different on any site) so do you guys no any site that tells you how to do some basic stuff to keep your car on the road AND STILL TELL YOU WHAT NOT TO DO? lol. thanx-james
    P.S....what does happen if i dont bleed from all four :confused:
  2. Mavaholic
    If you don't bleed all 4 wheel cylinders, air will be trapped in the brake lines and your braking force will severely be degraded or non existent. Do Not drive your car until your braking system is fully functional. This is not the system that you can afford to take short cuts. If you cant get the bleeder screws out, replace the wheel cylinders and or calipers.
    What not to do is more common sense or experience. All you have to do is tell us what you want to do and somebody here has probably done it and will be happy to guide you along.
  3. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Either take it to a brake shop or work with someone who knows what they are doing. I went to Vo-Tech school for 9 weeks on brake systems and worked in a brake/ tire shop for a while. Brake systems can be easy to the experienced but dificult to the unexperienced. We can tell you things to look for when having troubles but were not there to see the whole picture. Don't take any chances, if you have never worked on brakes before. Brakes are a saftey item and should be done properly.
  4. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    listen up! these guys aren't making this stuff up. when bleeding, always start with rear passenger wheel first. (the farthest from master cyl.) then driver side rear, then passenger side front then last is driver side front. i put my brake hose into a jar with some brake fluid in it, then have a buddy pump and hold pedal while you open up the bleeder. tell helper not to let up on pedal till you lock up bleeder. repeat this until the fluid comes out with NO bubbles and fluid comes out clear. do this for all cyls. remember to keep an eye on the level in master cyl so you don't run it dry and suck in air!. once you are done, drive down your driveway (forward) and slam on brakes whith no hands on the wheel. it shouldn't turn either way by itself. best of luck and if you anren't 100% sure of everything you are doing, don't do anything and send it to the shop! best of luck.
  5. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Or you can take it to a shop with a power bleeder. It's not very expensive.
    To have a website with a list of what not to do would take an immense amound of bandwidth. There is usually one way to do it right, 8 million ways to do it wrong.
  6. lordzero
    Eugene oregon
    yeah i see what you mean
    well i guess it would be a pain in the a$$ to make a site with the wrong ways too...like a do's and dont's kinda thing..yeah im just gunna replace the bleeder nipples if i can get them out and if not im going to have some one tow it to a brake shop and do the work..thanx guys! -James
  7. jnord
    jnord senior member
    Tucson,Az
    1972 Comet 250 6
    bleeding brakes
    Scott has the bleeding right. If u drive it down the driveway,slam on brakes & it pulls u may have adj mismatch. u got drums ight?
    Also on drums if bleders aren't functioning right, the wheel clyinders may be craped up and need cleaned honed and a kit (or new wheel cylinders. Many things can cause some or your problems; if your unsure and don't feel confident get help or have it done good luck. Jan
  8. jeremy
    jeremy I build t5's
    Corona, Ca
    why won't your nipples work????
    pull off the wheel cylinders and replace them. don't jack around!
  9. Mavaholic
    My nipples dont work either.
  10. bmcdaniel
    bmcdaniel Senile Member
    Maybe you need to turn them more. :D
  11. jeremy
    jeremy I build t5's
    Corona, Ca
    I guess I was asking for that one.
  12. Mavaholic
    That didnt work, but, where the hell's my girlfriend? Their never around when you need some help.
  13. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Quote from 'Meet The Parents'
    Robert DeNiro
    "I've got nipples, can you milk me?" or something like that, he may of used the dudes name, but anyway, one of the greatest lines ever in a movie.
    Dan
  14. MavJoe
    MavJoe Certified Lunatic
    Sacramento, CA
    1971 Maverick Grabber
    In my case the bleeder valves weren't stuck but the wheel cylinders leaked (All four of em), I replaced all four, the two front brake hoses, the two front brake lines, and the Master Cylinder in addition to changing all the Brake Shoes. That was my first time through ever doing brakes I had a book which didn't tell me much but more importantly the people on this board and others. I got through it lordzero it's not hard once you do it once :D
  15. lordzero
    Eugene oregon
    dirty..lol
    i loved that movie! the guys talking about milking cats! HAHAHAHA...i was laughing forever! its dirty and wrong.....i love it! lol well thanx guys for you help...i really need it, in new to this whole car t hiong..im actualy a musician..i play bass guitar and upright bass in a jazz/funk band here in eugene oregon...small town too. so there isnt much tho learn here..oh yeh! im going to try and get a digital camera so i an get the pics up for you guys..i think you will agree that its a good find for $10!!!! im willing to put the money into it. ive always been a freak about mavericks and people told me i was stupid an nobody else liked them but me..then i find you guys...i dont think that we all are stupid! lol. i cant wait to kick his stupid toyota's a$$ in a little street rass with my 4 door mav..then he will see what i mean~ :p well talk to you later guys-james
