what to do??
Discussion in 'Technical' started by badmav70, Jul 1, 2003.
  1. badmav70
    badmav70 Member
    pittsburgh, pa
    missing my 71 maverick i6 3 on the tree :(
    Well, I broke down and got one of thoughts goofy shackle kits to even out the stance of my 71..
    So now IM getting tired of the 4 lugs.. The car is a 200 w/3 on the tree, it actually looks to have an 8 inch rear, would it be easier to just change the axles and drums?
    I have a parts Granada that I was going to take the stuff for my other mav, will the rear from that drop right in? It appears to have the 8.8 rear (has the rear cover not the removable pumpkin) is this rear end pretty much junk?
    and lastly i have 2 mavericks both were/are 200 i6's, ones a stick and the other is an auto, the stick car has the 8 inch, the auto car has the smaller rear 7.5 i think (rear cover, non removable pumpkin)
    Also I have 2 Granada's with 250 i6's, ones a stick and the other is an auto, the stick car has the 8 in, and the auto has the 8.8 I think (rear cover, non removable pumpkin) my question is, was this a common practice of ford then to have the 8inch in the stick cars?
    from what i understand the 8 inch was the stronger of the bunch (well besides the 9 inch)
    sorry about all the questions.. thanks in advance
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I would think easiest way to get a 5 lug rear is scavenge one from another Mav/Comet.
    Dan
  3. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    ok the granada that has the bolt on rear cover is a 7.5.......so you will be better off using the 8" from the granada......the rear out of the granada will bolt right up under your mav......the difference is1/2" per side wider so the granada rear end is total 1" wider than the stock mav rear end but the spring pads are in the same location. I hope this helps:)
  4. badmav70
    badmav70 Member
    pittsburgh, pa
    that does help, but the granada i have with the 8in im not parting out. i guess what i really wanted to know was would the spring perches line up... i'll have to look around some i guess.. im sure i can find a mav with an 8... thanks
  5. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    The 5 lug axles will NOT just slip right into the 4 lug housing. The
    bearings are different sizes . I know this because I tried the same thing.:(
  6. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    I have a spare 8 inch just laying in my garage collecting dust steve...
    -Todd
  7. badmav70
    badmav70 Member
    pittsburgh, pa
    do you deliver?? lol. is the rear you have 5 lug? what might you want for it? send me an email dford4u@aol.com
    i may just have to wait a bit, im going to start calling my 71 mav project getto. it could change at any time but it will always be getto lol
  8. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    steve as far as the swap goes, it was REAL EASY! to make your life easy, if the u-bolts are a pain to unbolt, just sawzall them off and get new ones. a spring shop near me made me a set of 4 for 7.50 each. there HAS to be a yard near you that has a 5bolt for your car if you don't want to mess with the granada thing. if you find one locally, and have questions on the switching, stay in touch with todd. he did the switch on our 100 dollar mav. i just drank one of those cold Warsteiners and held the droplight! maybe wes can help you find a rear. klinger has a million of them but he is pretty far from you. keep us informed. good luck!
  9. badmav70
    badmav70 Member
    pittsburgh, pa
    im sure i'll find one, i have a few yards up my sleeve, my parts 78 granada has the 7.5 rear in it i may not wast my time with it, but my 77 granada with the good 8 in is my driver im not taking parts off of it.
    like you said its just easier to get new u bolts. for the price its the best way to go!!
  10. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    Hi Steve, how are you doing? Aren't gonna see you till the PA meet hopefully, so hows it going, life treating you ok?:)
  11. badmav70
    badmav70 Member
    pittsburgh, pa
    im still breathing, so i guess i shouldn't complain
