which rear ends ratio?
Discussion in 'Technical' started by scott, Jan 12, 2003.
  1. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    anybody have any idea which ratio i have in my rear end of my 1970 ? 200cid motor with auto. the tag inside the door is all scuffed up so i cant read it. and of curse it is too darn cold to be sliding around trying to read the tag on the rear. thanks
  2. squeal1
    squeal1 Out To Have Fun
    Evansville, IN
    72 Maverick Semi Mod, 75 Project
    I don't know if this will help much but I have a 72 and it had a 2.75 from the factory with a 200cid
  3. bmcdaniel
    bmcdaniel Senile Member
    My '70 w/ 200 cid and manual trans came w/3.08's. According to my interchange manual if it has the 7 1/4" ring gear (removable rear cover) it could be either a 2.83 or 3.08. If you have an 8" ring gear (not likely, but with a removable center section) it could be a 2.79 or 3.00. You may have to look for a tag on the rear it's self or jack up the rear and count how many times the wheels turn for every rotation of the driveshaft.
