Who rebuilds steering columns for these cars?
Discussion in 'General Maverick/Comet' started by Hairy W Bush, Apr 17, 2023.
  1. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    The column in my car needs to be gone through as there are already obvious issues with it. I sent a request to Steering Column Services in California and unfortunately they do not service these cars.
    Anyone know of a place that does?
  2. Craig Selvey
    There is really nothing that goes wrong with the steering column in these cars. I have never heard of anyone having to rebuild theirs.
    What issues are you having?
  3. Tannersg1
    Tannersg1 Member
    Classified
    Are you talking about the bearings going bad? Maybe a bushing? Either one of those issues can be fixed by just replacing those parts. Measure what you have and start searching.
  4. Hairy W Bush
    Hairy W Bush Member
    Georgia
    There's several things going on and I was skeptical about attempting this, especially since most of my tools are in storage far from where I live. I have some here. But after hearing what it's going to cost I think I'm going to do my best.
    dyent and Shorty like this.
  5. krelboyne
    krelboyne Remember
    Salem, Oregon
    Tony Augustine repairs Ford tilt columns 1967-73.
    He is in Missouri. Fixed columns are much simpler to work on. He probably would do the job.
    6t8cougarguy@gmail.com
  6. Krazy Comet
    Unless the openings that secure the shift collar to jacket are busted out, not much to fix.
    T-bird & Lincolns excepted, majority of Fords in era are basically same. Mostly length varies.
    Tannersg1 likes this.
  7. Hairy W Bush
    Hairy W Bush Member
    Georgia
    thanks guys!
  8. BlueSkyMav70
    BlueSkyMav70 Member
    Garner, NC
    I am looking for a new steering column or mine rebuilt to remove the column shifter, any suggestions/
  9. Hairy W Bush
    Hairy W Bush Member
    Georgia
    I can't really tell you about removing the column shifter to convert to floor but it's been done on these cars but a new a thread will help you too.
  10. 71Mavrk
    71Mavrk Member
    Nevada
    I converted mine. As said before, there really is nothing to these columns except a couple plastic bearings. To get rid of the three on the tree shifter section, I just replaced it with one from a floor mount. They are hard to find but they are out there. I think you can use ones from other models but you need to research. I did not retain the wheel lock or any of the neutral safety switch assembly with my AOD conversion.
    Micah
  11. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I used the column collars from a 71-73 Mustang to convert over. They fit without modification and were easier to source than Maverick/Comet.
    Shorty likes this.
