I took out my windsheild becasue it was leaking water, so I took it out, I can ither take it to a guy for 70-100 bucks and get it done or pay for a new gasket and some other stuff, for mabe 80 mabe more or less.... help me out all!!!!!!!!!!!!!!!!!!! So this is what I know, I need a windsheild gasket... and some new yellow clips for the crome. I need to know everything!!!! what do I need to do this- tricks or helpful tips- a step by step on how to- what kind of cleaing do I need to do to the window and car frame- How clean does it need to be- Any triks on getting that tar/rubbery stuff off the car- I need to know all this in dumb a$$ terms so that I will understand it and get it done right, and have it last and not leak on my hands, or on my passengers feet Thanks, Jason
NO TIP ON WINDSHEILD BUT NOW MIGHT BE A GOOD TIME TO CHECK THE COWLS. POUR SOME WATER IN THE FRESH AIR GRILLE IN FRONT OF THE WINDSHEILD, LOOK UNDER THE DASH FOR LEAKS. THAT IS HOW I FOUND MINE. I THOUGHT MY WINDSHEILD WAS LEAKING. TURNED OUT TO BE ABOUT A WEEK MORE OF BODY WORK. GOOD LUCK ON THE WINDSHEILD REPLACEMENT. A GLASS SHOP IS REPLACING MINE. THEY SAID $40 EACH (FRONT OR BACK). GOOD LUCK M7A1V
My cowls They are fixed, well sort of, I've done osme body work done before, I umm umm put fiberglass over the vents, so thats how I found out how bad my window gasket was, took it out and it nearly crumbled in my hands!!! so I fixed the cowl also, when I took out my a/c box with fiber glass, the "hat" is good, but it was around the out side of the hat was bad. so now alls I needs to do is the window, but thanks, for the advice!! Jason
