Won't start with the key
Discussion in 'Technical' started by 74merc, Apr 30, 2003.
  1. 74merc
    74merc computer nerd
    1974 Comet
    factory auto car, jump it at the solenoid everything's peachy, hit the key, nothing happens.
    I've been through it, and I'm thoroughly confused. Someone please give me a rundown on the Maverick/Comet iginition wiring and such...
    So far I took what I thought to be the safety neutral switch at the base of the steering column, right next to the firewall, off, checked the connectors, two sliders, complete one circut the reverse lights come on, the other circut is complete in anything but park.
    I think this is not the safety neutral... dunno.
    So, where is the safety neutral? Any other thoughts?
  2. Tim Wilmoth
    Tim Wilmoth Member
    Southside Va.
    1972 Comet gt
    Is it a floor or column shifter? My chiltons manual has some good pics E-mail me @ tjw@gcronline.com and i will scan them and send the info to you if you need it. this site has wiring diagrams you can download http://www.maverickcomet.com Hope this helps,Let me know if you need the chilton info on neutral switch
  3. Atzy1
    Atzy1 MMB Sporadic Participant
    Bremerton, WA
    '75 Maverick 4d (302, AOD, MSD, PST); '77 Maverick 2d (302, C4)
    If you don't care about being original...
    That happened to mine, and I still don't know completely what's wrong. So, I found an "accesssory hot" wire, ran it to a pushbutton switch in my ashtray (where the cigarette lighter isn't,) then to the solenoid.
    Pushbutton doesn't make it crank unless the key is in the "on" position. Bingo! Turnkey theft deterrence.
    Yours,
    Atzy.
  4. 74merc
    1974 Comet
    my comet gt, thanks for the link and check your email.
    Atzy1, I had considered that, but I'd rather have the working switch right now, daily driver.
    btw, it is a column shifter
  5. Tim Wilmoth
    Tim Wilmoth Member
    Southside Va.
    1972 Comet gt
    no E-mail???
    74 merc I didnt get any E-mail but I have a chiltons with pretty good details on nuetral switch.Let me know on here if ya want me to e-mail ya the pics Later "my comet gt"
  6. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    Go to Charlie Ping's site and call up the electrical drawings.
    Look at location B4 for the starting motor relay. Follow lead 32 to the next page to location B7, still as lead 32 to the starting position of the ignition switch.
    The drawings should give enough help to see what wiring is involved.
  7. 74merc
    1974 Comet
    heh, I didn't realize Charlie had electrical info on his site...
    turns out it wasn't the safety neutral. The box under the dash, a capacitor, a few other things and a relay on a PCB, one of the connectors had corroded and burned.
    Ignition relay? Where can I find a new one? I pulled one from my other Comet, got my daily driver running, but...
    thanks guys
  8. Jerry
    Jerry Member
    Woodstock, GA
    77 Maverick 2dr 302, 74 LDO
    Isn't that the seat belt lockout? Do you also have what looks like a reset button next to your washer reservoir? I had a 74 that was jumpered there, I thought, to go around the seat belt lock.
