4 1/4 BS with 275-50x15 fit
Discussion in 'Technical' started by MaverickGrabber, Dec 3, 2005.
  1. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    centerline dont make 4 1/4bs so went with the 4 1/2 with a 1/4 spacer 275-50x15 MT drag radials have a little over 1/4"of a inch to the spring set in the back seat and no rub anywhere had about 1" inch still ..10"inches of tread on the ground
  2. MaverickRunner
    MaverickRunner Member
    North Port Florida
    73 Maverick 302
    looks good....BUT be careful with those spacers!!!!
  3. MaverickGrabber
    Cardington, ohio
    the spacer was on the old rims there not the cheap ones... it had a 1/4 and another one that was a 1/8th going to get longer ARP lugs too
  4. MikeG747
    MikeG747 Member
    Arkansas
    Glad they fit. Looks great. (y)
  5. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I can't believe they fit. I know they would rub on mine...
  6. MikeG747
    MikeG747 Member
    Arkansas
    After reading all the posts about tire sizes that everyone has tried, I have ordered new wheels & tires for my 74 Grabber. Like alot of others I wanted the widest tires that I can put on the rear & keep them in the fender wells. I ordered Cragar SS 15 X 8's for rear & 15 X 7's for front. I ordered Goodyear Eagle GT tires. 4 1/4th Backspace 275 X 60 X 15's rear & 225 X 65 X 15's front. My tire guy says he will experiment to make sure they will fit without rubbing. It will be the end of next week before he get's them in. I will let everyone know if they work
    Mike:)
  7. T.L.
    T.L. Banned
    Southern Colorado
    With my stock rearend, 245/60-14s rub the inside frame-rail with a 7-inch wheel and 4-1/4" backspacing. They almost touch the leafspring...:hmmm:
  8. MaverickGrabber
    Cardington, ohio
    on mine the 275X60X15's being 28"tall would have not cleared with out rolling the lip ....and the 275x50s was a bit wider the 60s hasTire Tread Width:8.9'' and the 50s areTire Tread Width:10.0''
  9. MaverickRunner
    North Port Florida
    73 Maverick 302
  10. T.L.
    T.L. Banned
    Southern Colorado
  11. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    Looks good Dave, I think the long studs and open ended lug nuts would be a great investment for you!! Don't want to do the 3-wheel dance like happened to Todd!!(y)
  12. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Looks nice Dave,, success!! When I had my 72 grabber I did not have to run wheel spacers when I had 8" cragars with 10" tread. It was close though. When I bought my stallion and put on the cragars, I had to get wheel spacers, the tires touched the leaf springs. So moral to the story is, everything is not always the rule with these cars.
    Dan
  13. MaverickGrabber
    Cardington, ohio
    no 3-wheelen for me :biglaugh:
  14. MaverickRunner
    North Port Florida
    73 Maverick 302
    :lolup: I will never forget :rofl2:
  15. MikeG747
    MikeG747 Member
    Arkansas
    Tire Shop
    My Cragars came in so I went to the tire shop today. They mounted 275 x 60 x 15 on rear & 225 x 70 x 15 on front. It looked like my car was lowered. :confused: The tires tucked under the fender wells about an inch. They would not rub anywhere however I didn't like that look. We studied many tires sizes & determined that if we put 275 x 50 x 15 rear & 215 x 60 x 15 front it will give me the look I am wanting. He is ordering BF Goodrich TA Radials. They will be in in about a week. I will let you know how they work.
    Thanks, Mike:)
