Pictures of the factory floor shift hump installed
Discussion in 'Technical' started by olerodder, Jul 27, 2013.
  1. olerodder
    olerodder Member
    NorCal
    I am getting ready to cut my fab'd tunnel 70 out and replace it with a 71 tunnel. I have a factory floor shift hump and would like to install it for a cleaner look other than just cut a hole in the tunnel.
    Does anyone have a picture of one installed?
    Thanks,
    John
  2. mav1970
    Don't forget to take pictures as you go. I'd like to see what you have to go through to get yours to fit :tiphat:
  3. olerodder
    olerodder Member
    NorCal
    I will do that.
    Here is what I have to start with. I'll take the crossmember off since I don't need it. We mod'd mine and since my car is back-halfed I really don't need the structure.
    I hope I got enough of the floor to make a smooth transition.
      File size:
      868.1 KB
      141
      File size:
      1,018.8 KB
      125
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    There should be dimples in the top of the 71 tunnel indicating where the hump is mounted. If not I have a tunnel and a hump that I can mock up.
  5. olerodder
    olerodder Member
    NorCal
    I looked for the dimples but don't see any. It could be because someone cut holes and then tried to tack them back in.
    I would appreciate it if you mocked them up so I can get an idea of where they go.
    Thanks
  6. maverick1970
    Missouri
    I looked closer and there is only a dimple in the center of where the hump would mount. I pretty much have the same parts that you already have. The is pretty much one point where the shifter hump fits the tunnel best. You can see the dimple in the second picture.
  7. olerodder
    olerodder Member
    NorCal
    Thank you for the pictures, they really helped.
  8. olerodder
    olerodder Member
    NorCal
    One last question, do you know how much of the tunnel is cut out when the hump is installed?
    Thanks,
    John
  9. 71gold
    if it is a factory floor shifter going in...very little...:yup:
  10. olerodder
    olerodder Member
    NorCal
    Not factory Frank..................but close:burnout:
  11. 71gold
    just cut out what you need to get the shifter mec. in through the tunnel.
    if it's a cable shifter all you need is a...hole for the cable...
  12. olerodder
    olerodder Member
    NorCal
    Frank, when the factory put in the hump, did they screw it onto the tunnel or did they spot weld it....................or both?
  13. maverick1970
    Missouri
    The hump was screwed to the floor. These pics should help indicate the hole size.
  14. olerodder
    olerodder Member
    NorCal
    Thanks again for the pictures.
  15. maverick1970
    Missouri
    Hope they help. Looking forward to seeing what you are doing. I have plans to do something similar on our 70's
