how do i jack up my back end of the maverick
Discussion in 'Technical' started by justin has a 74, Aug 12, 2009.
  1. justin has a 74
    kentucky
    do they make blocks or something for this:huh:... like a 3 inch truck lift:rofl2:
    my fat tires are rubbing (probably due to the tire ot being balanced) and i want to keep them on:burnout:
  2. Dave B
    Buy some air shocks.
  3. justin has a 74
    kentucky
    already have them.. do i get ones that can handle more pressure
  4. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Nope, blocks won't work - Mav leafs are mounted under the axle, so any block you add would lower it. Buy some 4 leaf leaf springs to get your ride height back. Ditch the air shocks. Air shocks = problems. Resist the temptation for huge shackles too.
  5. Mavman72
  6. Mavman72
    Get new springs...Really the only(proper way)
  7. Corbin Johnson
    :D Good answer :rofl2:
  8. Dave B
    Flip your rear end to below the springs, then get some oak blocks. It's the 70's all over again!!
  9. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Sad to say I was going to suggest that(minus the oak blocks), its what we do to allot of leaf sprung jeeps for a cheap 5" lift. :rofl2:
  10. Mavaholic
    First of all you should get tires that fit. Second of all jacking up the rear shifts weight towards the front of a vehicle that is already nose heavy. Lastly, air shocks put more pressure on an area that was not designed to support the weight of the car. But if you insist on working with what you got, get rid of the air shocks and have your springs reached. Very cheap fix.
  11. Craig Selvey
    Yes....get tires that FIT.
  12. Rando76
    Rando76 Member
    Claremore, OK
    Agreed. If you really want to run air shocks, build a brace that spans from frame rail to frame rail and mount the upper shock mounts to it. Otherwise, air shocks will tear out the upper shock mount. I have seen several cars with this damage.
  13. justin has a 74
    kentucky
    thats not cool:D
  14. Bryant
    you can get what is called a flip kit. its normaly used to lower mini trucks but it will raise a car. you will have to do something custom to mount the shocks if you use this kit.
  15. maverick maniac
    maverick maniac Banned
    owensboro ky
    You can get longer shackles to , old school ,,,
