backspacing and 275 tires
Discussion in 'Technical' started by Zechs_wind, Dec 9, 2004.
  1. Zechs_wind
    Zechs_wind Old School Ford Rules =]
    757, 434, Virginia
    1974 Ford Maverick, free 1970 Maverick that needs everything.
    Howa-bout-cha everyone I have one of them infamousness questions that come up ever so often. I have a stock 2 door 74 Maverick that I want to equip 275/60 tires on Cragar’s Series 610 15 x 8 rims. I went through the past posts on this topic, but the more I read, the more confuse I got :cry: about backspacing. Do anybody have any new info or can help on this old question :confused: ?????
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    If you can fit a 8-inch wheel of the back of your Maverick without rubbing, I'd definitely like to know about it...
  3. Mavaholic
    You can get a 8" wheel on a stock rear as long as the backspacing is 4 to 4 1/4". But I doubt with 275 r 60 without rubbing issues. Rolled fender lips would probably have to be done with any size tire.
  4. Zechs_wind
    757, 434, Virginia
    agh:slap: 8 inches to wide and 60 series to tall, guess I better stick with a 7 inch rim and 50 series tire but if I use this combo can I use a 4 inch backspacing?
  5. Mavaholic
    Its not the 60, its the 275 that will probably give you problems. I have run 245r60x14 on my stock 77 and had bunches of room. This was on a 6" rim. My Sprint has 255r60x15 on a 8" rim with 4 1/2" of backspacing, but I also had a rear narrowed by 1/4" on each side for clearence. I tried the combo on my stock 77 just to see how it fit. The tires just barley rubbed the springs. The 50 series tires in my opinion are too short and dont look right because they dont fill the wheel well. I would think you could run a 245r60x15 on a 7" rim with around 3 1/2 to 4" backspacing with no problems.
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I kind of have a rule of thumb on this subject. Without body mods a 8' wheel with 4" of backspacing and up to a 9" tread. Next concern is height, too many variables to try and put a rule of thumb on that. Another thing, and I dont know why, but for some reason, some cars will accept what others wont.
    Dan
    ps I do have 17 x 8 rims on the rear with a 9" tread
  7. courier11sec
    courier11sec Member
    Tucson, AZ
    I have 275/60r15's on the back of mine. The rear is raised a bit, but not too drastic.
    An 8" wheel with 3 3/4 backspacing fits best so far as I've tried.
  8. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    I have a set of 295/50r-15 on mine...with no rubbing whatsoever! I had my wheel lips rolled though and I'm using an 8" rim with 4" offset..fronts are 215/70r-14's
      File size:
      95.3 KB
      135
  9. Mercurycruizers
    Venetia, PA
    Hey Cliff.....long time no hear!
  10. Zechs_wind
    757, 434, Virginia
    Ray how much lift do have because I am going to order some new leaf spring from J.C. Whitney to help aid my tires since my leaf springs are the orginal ones that came with the car?
  11. EFIMAV
    EFIMAV Member
    Davenport Iowa
    275s on rear
    Courier, can you post a pic of the 275s? Also, mavaholic. You say that the 255s fit on the narrowed rear but not the stock one. Was the rear narrowed or the springs moved inward. In ask because a narrowed rear would make the situation worse when compared to stock with regard to hitting the leaf spring, correct? Just trying to understand why they work on the narrowed rear.
  12. Zechs_wind
    757, 434, Virginia
    Wow :eek: 295's now thats admirable and your car stance is right on point (y) .
  13. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Here's 275/60/15. Not much room. They rubb on my 4 door but not on my two door. 8" wide, 4" back spacing. 4 1/4" wopuld be better This pic is of my two door.
  14. Zechs_wind
    757, 434, Virginia
    Russ are your wheel lips rolled or they stock?
  15. courier11sec
    courier11sec Member
    Tucson, AZ
    I'll try to take a decent picture soon. Lots going on these days. I'm not sure exactly how much lift over stock the shackles I made provide. Probably a good couple of inches.
    Now read on as I get a good talking too about using shackles to lift a vehicle.
