Lifter / Rocker Arm / Pushrods Fix?
Discussion in 'Technical' started by kboldin, Jul 1, 2012.
  1. kboldin
    Santee, CA.
    Opinions/Options??
    So I have a 69k motor, seems to be pretty strong but I'm getting a tic under acceleration (when the secondary opens). Under normal acceleration no problem.
    I have a 1972, 200ci, automatic, hyro lifters.
    The tic is definitely in the valve train, lifters, pushrods and or rockers. I know there are products like "honey" but I'm leaning toward a mechanical fix.
    Replacing the pushrods with longer ones, using different angle rocker, going with the adjustable rocker arms etc… Has anybody had good success and if so what did you do? Also, I prefer not to pull the head but I will if necessary.
  2. 71gold
    back the timing up a few degrees...:Handshake
  3. kboldin
    Santee, CA.
    I'm at 12 degrees (spec), go to 10 and run it?
  4. 71gold
    back it up a few and see what happens.
    you may have gotten some bad gas...:yup:
  5. kboldin
    Santee, CA.
    I suspect there is old gas in the tank, I put about 5 gallons in when I picked it up a few weeks ago. The carb was varnished up quite a bit and I rebuilt it first thing! I'll run it to E and fill it with supreme, back it off two degree's and see what happens. I believe the car was sitting for some time. If not, I'm leaning toward an adjustable rocker assembly.
  6. Resto
    Resto Benders Evil Twin
    Yuma AZ
    Ditto on all of the coments aforementioned, Id spray some carb cleaner down the throat, but thats just me.:)
  7. Craig Selvey
    Sounds like spark "pinging" to me.
  8. baddad457
    baddad457 Member
    Opelousas La.
    Me too. (y) Run a higher octane fuel, or back off the timing. He mentions the secondary's opening, what carb is on it ?
  9. kboldin
    Santee, CA.
    Carter YFA one-barrel. It's when the secondary circuit opens (squirt of fuel) under full acceleration.
  10. kboldin
    Santee, CA.
    I don't believe what I'm hearing is "pinging", there is a distinct valve train "ticking" under load. I’m more than willing to make the adjustments and run premium but I do think it’s going to be some time of mechanical repair.
  11. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Are you sure its not an exhaust leak?
  12. kboldin
    Santee, CA.
    99.999% positive its not an exhaust leak.
  13. groberts101
    groberts101 Member
    Minneapolis, MN
    if it is in fact a lifter tick.. then it should be LESS pronounced after cold start up/take off then when hot as the oil is thicker and cushions better.. as that previously mentioned motor honey would do as well.
    first of all.. check oil pressure since it sounds like you may have pressure issues under load.. and then proceed to check valvetrain.
    A worn cam/valvetrain or collapsed lifters are also another possibility and pulling the valve cover and checking preload would be the next best way to diagnose. You may just need to cinch down a rocker or two to get it quited down, is all. If it's non-adjustable( and I assume it is).. then going to a longer pushrod can help band aid slightly.. but you can't go overboard as geometry/tip sweep will change too much and cause other issues more severe then the one you now have.
  14. baddad457
    baddad457 Member
    Opelousas La.
    You are hearing pinging. It used to commonly be called "valve clatter" It's not the valves or valve train you're hearing, but many small detonations colliding with each other inside the cylinder as the piston is coming up the bore. This can destoy a piston.
  15. spxer
    spxer Member
    Raleigh NC
    pull the valve cover and check all the rockers to see if 1 or more is obviously looser than the rest
