trans to engine problems
Discussion in 'Transmissions' started by my70mav, Aug 13, 2010.
  1. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    ok guys its time to put the engine and trans in, but whenever i put the trans to the engine the converter hangs up and wont spin.if i back it up an 1/8 inch it will spin.i cant seem to find the problem.
    i made sure the converter was fully seated several times.i made sure the converter nose fits in the crank.if i remove the flexplate and mate the trans, the converter spins freely.i made sure the the flexplate is on the right way.i am kinda at a loss now,any ideas or anything i can check. it is 26 spline c4 on a 91 302.i am using a 157 tooth set up.thanks.
    this is the flexplate i have
    http://cgi.ebay.com/ebaymotors/NEW-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    this is the converter
    http://www.summitracing.com/parts/SUM-G2707-10/Application/?prefilter=1
  2. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    i just stood the trans on end and spun the converter,the center hub moves 1/8" out of round side to side. gonna call summit and see what they say.
  3. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    took it to a converter shop and it is fine,the shop said there is some play side to side,now i guess i need to make sure the bellhousing and pump are set all the way in.i am open to suggestions on stuff to check.
  4. baddad457
    If you have any long small block head bolts, take 4 and cut the heads off, you can then use these as guide pins in aligning the engine to the transmission. Screw two each per side into the bellhousing bolt holes, Line the studs into the bellhousing holes and slide the engine onto the transmission (or vice versa)
  5. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    i've been doing something similar by threading some longer bolts in the lower outside corners from the front of the engine.it goes on the dowels fine and slides right up except the last 1/8 inch or so.i do have the block plate installed also.
  6. PaulS
    The bind that is occuring in the last 1/8" is a clearance problem - it shoulf have about 3/16" to 1/4" of play in the torque converter with the engine and transmission bolted together. The converter is most likely not all the way into the pump.
  7. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    does anyone know what the measurement from the bell housing to the face of the pump?
  8. 71gold
  9. baddad457
  10. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    yeah it a 50oz with the appropriate 50oz 157 tooth flywheel
  11. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
  12. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    yep, i have a pan filled converter and i need a case fill converter, i bet the extra .3 inches is causing the binding.now to see if summit will/has a 3000 rpm case fill converter to swap for me.
    has anyone else had this issue?
  13. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    i am goin in circles here,converter is fine. now its down to flexplate or running 2 block spacers.
    can i run 2 spacer plates?
  14. PaulS
    Two spacers is not the answer.
    The converter and bell have to be matched.
    The flexplate and the converter have to be matched.
    The flexplate has to be counter-balanced to the engine.
    If you have a pilot bearing or bushing in the end of the crank it has to be removed.
    The converter pilot has to match the crank pilot recess.
    Take some time to carefully check everything out and correct the problem.
  15. don graham
    Are you sure the convertor is going all the way in to the bellhousing. There should be 3 clicks going in. If you don't get the last click in it will bind.:)
