302 without frame mounts
Discussion in 'Technical' started by Tomhopson, Feb 28, 2011.
  1. Tomhopson
    Tomhopson Member
    Jacksonville Florida
    I need help fast. Is there any way at all for me to put my 302 in my maverick without the 302 frame mounts. I have to put the engine in as soon as possible because my 200 died.
  2. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    I used 64 falcon mounts in the model A. (One side is longer than the other, so you have to get two of the shorter mounts.) These have a stud pointing down, so with a little angle iron, a drill, and a welder, these may get you buy, without tearing up the frame.
  3. coryz28
    coryz28 Member
    tulsa oklahoma
    1976 maverick
    I used my 250 6cyl stands with 78 ford f-150 mounts and i think you could squeeze by with the 6cyl crossmember but had a double hump crossmember so i used that ,did a lil grinding here and there. I think the regular v8 mounts are just a waste of money. My car is running and drives great. Just my 02 cents.
  4. Tomhopson
    Tomhopson Member
    So you used the frame mounts that came with the maverick and used 78 f-150 motor mounts?
  5. Joe Dirt
    Yes 6 cyl mounts turned backwards and 74-79 sbf mounts for a f100 my cars also like this and works fine
  6. coryz28
    coryz28 Member
    tulsa oklahoma
    1976 maverick
    I got my idea from joe dirt.
  7. bmcdaniel
    If you do a search...
    I used taller 66 Mustang mounts bolted right to the frame horns with 3/4" spacers between the mounts and engine block.
    grumpysrg likes this.
  8. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    PM sent to you.
    Thanks,
    Rick
  9. vwsandwitch
    vwsandwitch New Member
    ca
    71 manerick
    When you guys said that you fliped ths 6 cylinder fram mountd backwards, did you mean on the other side of the frame, or literaly backwards and grind th mount to fit flush.
  10. Joe Dirt
    swap sides
  11. 51Cards
    51Cards Drive it like ya stole it
    Oxford,N.C.
    1970-302ci. Maverick 1964 390ci.Thunderbird
    I used the mustang motor mounts NO frame mounts just bolted them to where I removed the 200 frame mounts with a thick walled spacer.
  12. 351 celi
    351 celi Member
    Lexington, SC
    '77 2 door LDO converted to '72 grabber
    Are there any induced hood clearance issues by using the "Joe Dirt" approach vs. purchasing the mustang/mav v8 frame mounts and Maverick 302 motor mounts? I know the mustang motor mounts are taller than the mav mounts is why I ask and I am installing a 351W. Thanks!
  13. 351 celi
    351 celi Member
    Lexington, SC
    FYI, Joe Dirt worked for me, sits very low, so much in fact, my steering linkage would touch my oil pan on full turn in both directions. I shimmed the mounts at the block for clearance, still no interference with the hood. Thanks!
  14. Joe Dirt
    You using a truck oil pan?
  15. bborsom
    bborsom Member
    joliet il area
    1970 tubbed body in white and 1972 grabber yellow with orange stripes
    has anyone tried joe dirts set up with a cleveland and tubular automotive headers. need more steering clearance
