8" Rear End Gears
Discussion in 'Technical' started by Erick-Mav, Dec 14, 2004.
  1. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    Thanks to some information posted on this board, I found an 8" rear end at the junkyard with 3.40 open diff gears off of a 75 Bobcat wagon. I couldn't get just the pumpkin off so I had to get the whole rear end for $59 (+core&tax). The door code indicated that it should have 3.55 gears, but they were only 3.40.
    My question is: I plan on swapping out the 2.79 gears in my Mav for the 3.40's. The car will be mainly used for cruising on the street but occasional at the strip. How high will the car be revving when cruising down the highway at 60mph or so? The car has a stock 3 speed manual trans and I'm thinking the gears may be a good compromise for quickness yet still streetable but don't want to blow up the engine driving on the freeway. What do you guys think? Thanks.
    -Erick
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I am only guessing, but I would say your RPM's at cruising speed should be
    about 5-700 higher.
    Wide range, but it's just a guess.
    Seth
  3. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
  4. Thack
    Thack vision advicator
    Moreno Valley Ca
    That's pretty cool but, it won't calculate overdrives
  5. Erick-Mav
    Oceanside, CA
    Great info...looks like 3.40's will add 400 to 500 RPM, and a total cruising RPM of 3000 or less. Sounds tolerable. Thanks.
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Good find.
    I think you'll really like them.
    Let us know!
    Dave
    Throw your highway chunk back in the rear and get your core charge back!
  7. EFIMAV
    EFIMAV Member
    Davenport Iowa
    I don't think bobcats have 8" differentials, do they. Isn't it Mercury's version of a pinto? That is a 7.5?
  8. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    The V6 Pintos & Bobcats came with 8" rears...
  9. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    3.40s are very tolerable on the street. Won't be a problem for you at all...
  10. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    was that bobcat a 4 banger???????????
  11. Erick-Mav
    Oceanside, CA
    No, it was a V-6. It had some pretty cool blue rims w/ beauty rings too. I wonder if the Pinto guys would need them.
  12. Acornridgeman
    Wisconsin
    Great find! Next time take a camara - we love pictures! (y)
  13. scott
    scott Member
    new jersey
    gittin the itch....hope it isn't too cold in PA next weekend.
  14. PeytonMaterne
    PeytonMaterne Member
    I went to randys ring and pinion (I think it's differentials.com) and was playing with their calculator. It has auto, aod, manual, and 5spd and it figures them all at once. Check it out.:bananaman I love the dancin nanner.
  15. scott
    scott Member
    new jersey
    ok...so one more possibly stupid question.... will the rear be a direct fit for my driveshaft?
    thanks
