Vinyl top project ... mostly went OK ...
Discussion in 'Cosmetic' started by dmhines, Oct 23, 2005.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I still need to reinstall the trim ... gonna get new clips ...
    Once lesson I learned ...
    DON'T REMOVE THE RAIN GUTTER TRIM ... IT WILL DRIVE YOU INSANE PUTTING IT BACK ON!
    I figured I would tuck the vinyl under the trim ... wouldn't fit so I ended up popping it off for no reason. The driver side went on fairly well. I screwed up the passenger side pretty good and out of frustration I dented the roof (don't ask) . :mad: :mad: :mad:
    Here are some pics ...
  2. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    That is going to be one good looking car. You ought to drive it up to TN and let that nice old lady see it.
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Wow!! Talk about setting a car off. That works for sure.
    Dan
  4. dmhines
    Cumming, GA
    Place the windshield chrome to see how it looks ...
  5. Ford_Motorheads
    Ford_Motorheads Ford Addict
    Phoenix, AZ
    1961 Falcon, 1967 Ranchero, 1969 Gran Torino GT, 1974 Ranchero GT 1976 Mustang Stallion, 1977 Mustang coupe, 1978 Mach 1, and 2 1978 Cobras
    Dan, your car is looking great. Way better than I imagined. (y)
  6. Jamie Miles
    Alto, GA
    I've had a few
    Looks good Dan! That sucks big time about that dent though. :(
  7. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Should'a left it the way it was. Gonna be hotter than Hell in the summertime...:tsk:
  8. dmhines
    Cumming, GA
    I let my temper get the best of me. I got up underneath and pushed the dent out so it isn't nearly as noticable ...
  9. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Looks sweet! Great job! Can't wait for a how-to.. if it's easy enough, I'll replace the one on my Grabber myself when I get to that stage...
    -Corbin
  10. Earl Branham
    Lugoff, SC
    Dan; Nice. Better than I thought it would be. Good job!
  11. tim keck
    sharps chapel,Tn
    That car is screaming for a v8 Dan.Looking very good.
  12. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Hmmmm.....I think it looked better without the vinyl top.
    Take it off and let me see it again.
    j/k-Looks great! Nice Job.
  13. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    I like it...but then I would, wouldn't I? :p
  14. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I like vinyl tops. Took mine off 10 years ago though.
  15. dmhines
    Cumming, GA
    I was gonna take a whole bunch of pictures for the how-to ... but once I got started I didn't. :(
    I can tell you that if you go to your local Barnes an Noble and take a look at the Camaro restoration book there is a Chapter on Vinyl Tops. I followed those directions exactly.
    Here are some pics of where I set up the center line to make sure the top and seams were perfectly centered on the roof. I use a chalk line to snap it and then a marker.
    I did the driver side first and then the passenger side. The passenger side came out slightly better because the driver side has some wrinkles near the rain gutter.
    I have some major tips ...
    Glue down only 6 inches of top at a time. If you do more it will be hard get it down without wrinkles. The key is to lay the vinyl down flat and stretch it as little as possible.
    Also ... the adhesive sets almost instantly ... you have maybe 10 seconds if you want to try and lift and and put it back down.
    Once you have the top glued down roughly trim out the sides and front and rear windows. Trim big becuase there is no way to repair it if trim short.
    Use a piece of chalk and trace out the outlines of the windshelds. Then trim 3/4 inch outside the line for the correct overlap. I used a kitchen rolling pin to smooth it out.
    I use weatherstripping adhesive in the rain gutters for a better bond (as per the Camaro book) and will use it in the window channels as well. I have not glued them down yet.
    Once I had everything glued down I went back and did a final trim around the rain gutters.
