right toploader?
Discussion in 'Technical' started by jean282, Nov 29, 2005.
  1. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    hi i would like to know if a toploader whit tag# RUG BF1 and if the shifter is mounted at the right place.
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    The best way to know is to know what car it came out of. Year and model.
    You could also measure the tranny.
    If the overall length is around 24", then it is right.
    If it is 31" or thereabouts, then it won't work. (at least not cost effectively)
    You also need to measure the very tip of the tranny.
    The little nose on the input shaft, that rides inside the crank bushing.
    If the nose measures under 1", then it is wrong.
    If it is over 1", then it is right.
    To recap:
    Nose must be over 1" long, and length of tranny (nose to tail shaft end) should be around 24".
    If either of those is off, then get another tranny.
    I don't remember the exact measures off the top of my head, but if you loosely use what I gave you, it will work.
    Dave
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    That looks like a 3-speed ... a 4-speed has 3 linkage rods .. not two like that one ..
  4. rayzorsharp
    Dan, I think if you look a little closer you'll see the third rod. It's hidden by the last one. You can make out the shift lever if you look closely and then you can follow the rod.
  5. ratio411
    ratio411 Member
    Pensacola
    I count 10 cover bolts.
    A 3 speed is 8 bolts, I'm pretty sure.
    Dave
  6. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    According to your tag you have:
    RUG-BF1 1972 Fairlane 351 wide ratio After 12/1/71 28-spline
    I suspect Fairlane means Torino.
    http://www.4speedtoploaders.com/
    www.toploaderheaven.com
    As far as 'will it fit?' These cars never came with TL's so some mods
    or changes to the shifter, tailshaft or shifter opening may be required.
    Seth
  7. ratio411
    ratio411 Member
    Pensacola
    No Fairlane in 72... :)
    If it is Torino, it won't work in a Mav.
    Wide ratio is a good thing though. If it was a short shaft...
    Dave
  8. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    the tranny is from a 73 gran torino sport the lenght is 24" and the nose measures more that 1" that is correct . Is the shifter is bolted to the right place to fit on my comet? i send you another pics for stop the confusion :)
  9. ratio411
    ratio411 Member
    Pensacola
    A short shaft toploader 4 speed is identical in every way, that matters, to the toploader 3 speed that was available in our cars.
    If you start with 3 speed car, all you have to do is pull the gearbox and shifter.
    Then put the short tail 4 speed gearbox and shifter in it's place...
    Done.
    Don't even have to disturb the bellhousing.
    Easy-cheezy :tiphat:
    Dave
  10. grbmaverickmo
    Aquashicola, PA
    My book says late72 torino small block.And it looks like the plate that relocates the shifter from the mid mount to tailmount. it should be right for your car .But I`m no expert .I`m doing the toploader game in a mav agian after about 10yrs. Hope this helped Chris
  11. ratio411
    ratio411 Member
    Pensacola
    WOW!
    That turns my world view upside-down!
    I never knew they made a short tail Torino 4 speed...
    I have never seen one before now.
    If it measures the same as a C4, then it should go just fine.
    The shifter might not be exact if you have a factory 3 speed Mav with floor shift.
    I would certainly try it! The Torino is a longer car, so the shifter might sit a little further back. Wouldn't think it would be a lot though.
    A wide ratio tranny is the way to go.
    Dave
  12. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    I suspect you are correct, but the availability of short shaft TL's must be a problem since we see so many hacked up tranny housings posted in pics here.
    Seth
  13. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    i removed the tranny and pedal setup from the torino and all seem to be original. thanks for help
  14. dmhines
    Cumming, GA
    If you are thinking the Torino Clutch pedal and linkage will fit a Maverick you are mistaken .... :(
  15. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    i know i think i will sell it on ebay. how much do you think the pedal setup and all the linkage worth?
