99 Cent Propless Hood Hinge Mod.
Discussion in 'General Maverick/Comet' started by PART-TIME, Jun 13, 2007.
  1. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    1) Locate adjustable prop rod.
    2) Insert rod and adjust hood to desired height, making sure you have the rod centered and hood is level on both sides (Choose a height other than the standard/original prop rod height.) PICTURE 1
    3) Drill a 1/4" hole from the inside out. PICTURE 2
    4) Get (2) 1/4" x 2" bolts and cut off threaded portions. Grind ends smooth. PICTURE 3
    5) Insert pins and you have a 99 cent propless hood. PICTURES 4 AND 5
  2. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    TIRED OF BANGING YOUR HEAD ON THE HOOD LATCH WHILE WORKING IN THE ENGINE COMPARTMENT?
    1) Find a friendly helper!
    2) Have your helper hold the hood all the way open until it stops. PICTURE 1
    3) Drill another 1/4" hole using the previously drilled hole on the inner hinge rail as a guide. PICTURE 2
    4) You should end up with one hole on the inner rail part of the hinge and 2 holes on the outer plate. PICTURE 3
    5) Insert pins and hood will stay in vertical position allowing plenty of room for working on the engine without fighting the prop rod or head banging the latch. PICTURES 4 AND 5
    WARNING: DO NOT ATTEMPT TO OPEN OR CLOSE HOOD WITH PINS IN PLACE!!!
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    That is quite a bit of leverage on the hood and force on the hinges ...
  4. Mavaholic
    I've seen that before, works pretty good.
  5. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Blown76Mav,
    Someone who does not know you should not be touching your car.
    dmhines,
    Lift your hood and clamp some vice grips in the sections where the holes are drilled and test it for yourself. There is not that much strain on the hood or the hinge.
    Mavaholic,
    Thanks Dennis
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I have done it before,, works great.
    Dan
  7. scooper77515
    The higher you place the hood when you pin it, the less force (in torque) will be applied to the hinges...
    So the second scenario would be pretty cool for working on the car and for shows...
  8. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    :idea: Great idea......Thanks(y)
  9. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    Never gave it much thought, but that looks like a good idea. I just may have to try it. Thanks for the info.
  10. Thack
    Thack vision advicator
    Moreno Valley Ca
    Great Idea I might have to do the to Tammy's.......that way she will stop buggin me for gas struts :D
  11. NICK DOMINICK
    Burke, Virginia
    I had never seen that before. Very good idea!!
  12. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Good idea. I think I would use quick release pins and drill another hole on the lower part of the hinge on the apron to store them.
  13. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    good idea.
  14. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    I don't bump my head on the hood now.;)
    Sometimes, it's good to be short.
  15. rayzorsharp
    I like it...I'll be trying it soon. Thanks :)
